Did you replace front and rear rotors or just fronts?I love my new brakes - MPP stock size giros and the gloc street compound pads. Absolutely precise braking. Multiple times without an issue
The car should have come with these!
All of themDid you replace front and rear rotors or just fronts?
Not trying to be a pain here ... but would you please provide links to each item you purchased?All of them
How about brake feel and linearity, pedal travel, etc?All of them
FrontsNot trying to be a pain here ... but would you please provide links to each item you purchased?
Probably worth making the investment ... deciding whether to wait for Tesla's Carbon Ceramic kit (whenever it becomes available) instead
Do you like your solution better?
Thank you for your feedback and for believing in us!I love my new brakes - MPP stock size giros and the gloc street compound pads. Absolutely precise braking. Multiple times without an issue
The stock are just inadequate for my driving, I have to get on the brakes a lot harder and sooner than any other Tesla I've had.
thank you !!!Fronts
Two-Piece Stock Diameter Front Rotors for Tesla Model Plaid and Long Range
Want to fit OE 19" wheels while upgrading your Plaid's brakes? Two-Piece Stock Diameter Front Rotors for Tesla Model S Plaid and Long Range are here!www.mountainpassperformance.com
Rears
Two-Piece Rear Rotors for Tesla Model S/X Plaid and Long Range
The Two-Piece Rear Rotors for Tesla Model S Plaid and Long Range increase the thermal capacity of your rear brakes dramatically!www.mountainpassperformance.com
Pads - you have to call them to order. Parts numbers are GPX191-GS-1 for the Fronts ($300) and GPX192-GS-1 ($240) for the rears
Eurofed (chamblee) did mine.thank you !!!
Quick question ... who did your install?
Tesla service? Someone private? Do they have recommended installers?
teamPGR's opinion after 2 days testing now:
Get the MPP rotors (oversized fronts) the brake cyl brace and some good quality street pads and the car will be 100% better than stock. That will probably cover most people who have a plaid in our opinion.
For the 5% that want to lap at a road course add a set of legit track pads - GLOC makes R12's that seem to work for us so far at medium power levels on street tires. There are probably other good options that would also be fine or better. At half power you can lap ~15+ times until you run out of energy without any brake issues (or other issues with the car for that matter!) With higher power after a few laps the brakes will start to get hot and you need a cooldown and can then go again.
If you go to full plaid power levels you are going to need to do warmup laps, then single push laps with a cooldown lap between, but by that point you also should do all the suspension arms, shocks, aero etc. etc. and you need to talk to Sasha directly to get all the goodies!
Notably we have not tried real track tires yet - we are limited to >=200TW for our upcoming event so that's what we have been testing on. Will be interesting to see what that changes. We are braking at over a g and roughly the same laterally with the setup as is - which is really good! - but could be better with better tires.
One serious caveat - if you are a newbie - go get a different (slower/cheaper) car first to learn how to find the line, hit an apex, threshold brake, work well with others on track, etc. This is not the car to learn on because it is so extreme and because it's not really possible to lap all day given the energy constraints. I'm available for anyone who wants some Plaid driver coaching...![]()
@Mczed Is that still an issue with Track Mode?Turns out the tration control uses the brakes so they heat up faster the harder you corner. Sucks for sure.
Source? I know Tesla does this in track mode for the Model 3 Performance, but with two independent motors in the rear, they can just use each motor for torque vectoring without having to use rear brakes.Turns out the tration control uses the brakes so they heat up faster the harder you corner. Sucks for sure.
Ive touched my rear brakes and they've been warmer than the fronts in regular driving... they're definitely usedSource? I know Tesla does this in track mode for the Model 3 Performance, but with two independent motors in the rear, they can just use each motor for torque vectoring without having to use rear brakes.
C'mon, drive the car hard and see how hot the brakes are.Ive touched my rear brakes and they've been warmer than the fronts in regular driving... they're definitely used
But…. Safety scoreC'mon, drive the car hard and see how hot the brakes are.![]()
