GSP
- Dec 28, 2007
- 2,565
- 795
1. 100A twist lock connectors are unwieldy. Imagine a CHAdeMO, but larger. Good luck finding a single phase one, too.
2. The Tesla onboard chargers are about the size of two large/old laptops put together and they weigh even more.
3. 72A x 240VAC = 17kW. If this portable charger is 98% efficient, it's going to be giving off ~350w of heat that needs to be dissipated. That comes to about 1200BTUs. The components needed to safely remove that heat from the charger adds weight and bulk, and will need to draw even more watts to operate.
It would be neat to have a "half SC" that can do ~60kWh. It would be similar to a CHAdeMO. If that's the case, why not just have destination charger location install a CHAdeMO and have a Tesla adapter at the front desk for use. This wouldn't be needed at a hotel since overnight stays should be able to fill a drained battery overnight with the HPWCs. There are options here, for sure.
Making an 80 A portable charger like bwa requested would take two Tesla chargers and a coolant tank, radiator, fan, and pump. It would be big and awkward. The lack of 100 A outlets or plugs means it would have to be hard wired, not convenient even for people with the skill to do so. Therefore, designing for the most common 3-phase outlets would be the way to do it (just as Tesla designed the UMC for the most common single-phase outlets). Using two of Tesla's European chargers would provide a 22 kW 3-phase charger.
The BRUSA 22 kW charger used in the European Smart ED would be great for this. It is very compact, smaller than two Tesla chargers. You still need the coolant tank, radiator, fan, and pump, which is why it is best to have any portable charger integrated into the vehicle by design.
GSP
