E90alex
Battery change wouldn’t make senseHow do you know there was no battery change?
For all vehicles simultaneously? Elon is good, but not that goodHow do you know there was no battery change?
This is due to new 2024 EPA rulesThe Model Y LR and P received new range estimates which is most likely due to change in thei battery pack. Do we have an EPA testing on the 24 year models that show how much kWh the EPA pulled out of the battery?
I guess they are switching to 4680 to benefit from the tax breaks in the US
Because its common sense. Why will Tesla change battery that will lower the range?How do you know there was no battery change?
They have actually done that many times in the past...And most people hardly understand what "capacity" of the battery means, they will still buy the car as they have no frame of referenceBecause its common sense. Why will Tesla change battery that will lower the range?
Where that?! Link?! A "Tesla fam boy" stated that and a lot of people are quoting him on that...Tesla has stated it’s due to EPA change
"For whatever reason"Most EV ranges where negatively affected. But some models fared better for whatever reason
I think they actually did exactly that. The AWD in the video above has 67kWh usable. This adds quite well to the new estimates on the website if they just add a few more cells and lower the capacity.They wouldn’t switch all Model Y to 4680 because 1) they can’t make nearly enough to supply the Model Y and Cybertruck and 2) even the gen 2 4680 cells in the Cybertruck don’t have enough energy density to match the new range figures for the Model Y.
You're making a lot of guesses and assumptions.I think they actually did exactly that. The AWD in the video above has 67kWh usable. This adds quite well to the new estimates on the website if they just add a few more cells and lower the capacity.
And your point 1 and 2 actually confirm the suspicion that they have to lower the capacity, because they don't have enough cells ... They can still lower the capacity on the Panasonics in the Plaids to lower costs.
Besides, you still didn't answer the rest questions - if there is a new EPA test, where is it? There is none.
Why only Y and S and not 3 which we know doesn't use the 4680s and doesn't qualify for the tax credit. Why not the Y RWD?
@AlanSubie4Life do you have an idea what types of batteries Tesla is using for the Model Y nowadays in the US?
You can, if the EPA says you can.2. You don't change EPA on "select models" if the testing changed for all.
Oh, I just saw, while the M3P didn't change their range, the M3LR did. It used to be 358, which... surprise surprise, drops about 6-7% to 333.Vehicles utilizing carry-over data may continue to use data generated under previous policy for as long as the tests are valid (i.e., no changes to the vehicle requiring new MPGe/range testing are required).
Correct, none of them are reflected on the Model Y. Send me the link where the EPA tested the Model Y, it is public information and easily available...The EPA made adjustments to their tests for EVs, which took effect in 2024.
No, they have to test it and publish it. "Goto" 1 above...You can, if the EPA says you can.
Ok, so you really have no idea what you are talking about...Oh, I just saw, while the M3P didn't change their range, the M3LR did. It used to be 358, which... surprise surprise, drops about 6-7% to 333
LOL. the Model 3 got the Chinese batteries in 2023 and the range was reduced from 358 in 2022 to 325+ estimation and finally settled on 333 in 2023. Hence no change this year.Because its common sense. Why will Tesla change battery that will lower the range?
No, you are confusing things. The "chinese batteries" you are reffering to are CATL. They are used in the SR, which doesn't have 333 miles. The 333 miles is a Long range model. It used to have Panasonic, but they changed to LG, from Korea, not China (Asia, still, yes...) This is why Model 3 doesn't have the tax credit in the US from 2024 onwards, because of the korean batteries...The Model 3 performance uses/used? Panasonic and they still qualify.the Model 3 got the Chinese batteries in 2023 and the range was reduced from 358 in 2022 to 325+ estimation and finally settled on 333 in 2023.
The news article clearly said the new EPA guidelines caused a revision in range. There was no battery change. Did you even read?LOL. the Model 3 got the Chinese batteries in 2023 and the range was reduced from 358 in 2022 to 325+ estimation and finally settled on 333 in 2023. Hence no change this year.
Your “facts” are wrong.No, you are confusing things. The "chinese batteries" you are reffering to are CATL. They are used in the SR, which doesn't have 333 miles. The 333 miles is a Long range model. It used to have Panasonic, but they changed to LG, from Korea, not China (Asia, still, yes...) This is why Model 3 doesn't have the tax credit in the US from 2024 onwards, because of the korean batteries...The Model 3 performance uses/used? Panasonic and they still qualify.
They also put an AMD Ryzon chip which uses a little bit more power in idle for the computer and hence the estimation of 333 miles.
Guys, I understand Tesla is confusing, they change a lot of things, a lot of things are unknown, but I mean this is a semi-ehtusiasts forum. If you are not factual about things or have some loopholes, just don't comment on that...
So Tesla is changing a lot of things here and there. Fact is - they are changing something in the specs - wether it is the battery reduction/something else causing more power (unlikely 10%) or a combination of both (most likely) - we can't know, but it is not "just" - EPA changed their guidelines...
