I just heard something from KW. The adjustable compression/rebound on coilovers are “low frequency”, mainly about weight transfer in corners. The daily comfort is more about “high frequency” compression/rebound, which is not adjustable and not changing when you adjusting the low frequency ones.
If that’s true, what’s the disadvantage to run a super firm compression/rebound on street?
@MountainPass
The adjustments on our dampers affect the low and mid-speed ranges, the high-speed forces do not change. This is VERY noticeable on the street, as most of the little bumps, splits in the road and other road imperfections cause the suspension to move in that mid-speed range. The high-speed range comes into play when you're hitting potholes, big bumps on the highway and things like that.
For suspension that is both capable on the track and as comfortable if not more so than OE on the road, the adjustment range we have is pretty ideal. We have just enough high-speed forces in the damper to be composed on the track without being harsh or bothersome on the road, and the low-speed adjustment range is so massive that every click is very noticeable and you can easily pick your ideal setting.
There was some mention about the dampers being hard to adjust and needing to remove the frunk - what we've done on our car is drill a small 1/8" hole in the frunk and then you can access the rebound adjuster with an Allen key. All other adjustments can be made on the ground by sticking your hand in there. If you're skinny enough you can even get at the rear rebound adjuster without needing to jack the car up!
I'm currently in the process of installing this MPP kit for a customer's vehicle.
Dfwatt, I've encountered the same issue with you; front jacked up high, rear was lowered. I found on the first post of this thread that the alignment dowel was ground down, I'm going to go back out to the shop & check if that's what's causing the issue with the front of his car being so high. I have about 1/2 to 3/4 inch of thread remaining on front shock body before the lower spring perch bottoms out but my concern is this: having the spring perch so low, doesn't that drastically effect spring rate?
I've installed many coil over kits on other vehicles & do a lot of alignments oriented towards road racing. Most other kits set pre-load, and then height is adjusted by adjusting shock body length. I'm concerned with dropping the lower perch in the front all the way down we are now losing spring tension. I'm going nuts over here, have just about every suspension component loose on my alignment rack thinking that some suspension component is applying pre-load but that's definitely not the case.
Adding spacer at the top and lowering the spring perch at the bottom to offset it has zero effect on the characteristics of the suspension, and the preload of the spring doesn't change (if it did, as the damper body length doesn't change, the ride height of the car would change!)
The body length/preload adjustment is a common misconception that has started with JDM type coilovers with body length and spring height adjustment (I used to also only adjust suspension with the body length 10+ years ago so I know where you're coming from!). You'll notice that on any real top tier racecars that there isn't anybody length adjustment - just spring perch offset. Why?
The reason is that the body length is set for the parameters of the car. You know the travel range you want (i.e. the car should not be able to hit the ground, no suspension arms should hit the chassis), and so the damper length is set so that at full compression, with the bump rubber nearly fully compressed, the body of the car is close to but not hitting the ground after taking into consideration tire deflection.
Once that is set, there is no reason to ever adjust it unless you're changing something major (like tire diameter or drop spindles for example). At that point, all height adjustment is done with the spring perch offset.
How much "preload" is on the spring at full droop is really an inconsequential value. In fact, if the damper has enough travel (as our AWD sports coilovers do) you can have so much droop that you have almost no preload when the suspension is fully extended. This gives the best ride quality over large pot-holes and drops in the road, as there is little to no chance that the suspension will ever max out on droop.
If you've ridden in cars that have only 1" of droop or so, you'll know that they ride horribly, even with soft springs. Why? Because as soon as a wheel encounters a dip in the road greater than the amount of droop available, the suspension effectively goes solid and the car falls into the hole!
For future suspension installs with those types of coilovers my advice is to set the body length so that the damper has 40% droop travel and 60% compression travel, assuming the car won't hit the ground when fully compressed. Then do the rest with the spring perch adjustment. If there is no tender spring, that will likely mean having almost zero preload on the spring to get the most droop possible.
Unfortunately, some of these kits just don't have much available suspension travel, so you're stuck in that case with not being able to do much!
