My front forks are coming today. Will be using this post as reference. Thanks for helping us.
Lowered my car by 5mm and 10mm front/back to get more negative camber. Front is 33mm with rear at 20mm. Both are now 5mm higher than MPP recommendation.
After the car is lowered, now I hear a some noise when the suspension is compressed. At my original install height, which were 10/15mm taller than MPP recommendation.
The noise will probably self correct over the next few days. If not, I’ll have MPP look at it at Laguna Seca.
Cool. Will do that when I swap street shoes for track shoes.Try turning the spring perch down 1 turn then back up 1 turn. See you at Laguna!
I just heard something from KW. The adjustable compression/rebound on coilovers are “low frequency”, mainly about weight transfer in corners. The daily comfort is more about “high frequency” compression/rebound, which is not adjustable and not changing when you adjusting the low frequency ones.
If that’s true, what’s the disadvantage to run a super firm compression/rebound on street? @MountainPass
Just want to thank you guys at MPP and @beastmode13
With this setting I was able to get to what for me is a perfect ride height – see next picture – but for guys tracking the car who want it almost scraping the pavement (or who love the slammed look!) it might make sense to use the helper springs rather than the top column and live with the possibility of some suspension noise– curious what Sasha and Jesse might say about this at MPP. I suspect there is a slight and perhaps unanticipated/unintended height difference between the newer aluminum column versus the original helper springs – perhaps MPP can revise the column height to rectify this? I have to confess I'm just guessing here and also that it's a bit surprising given that when visually you line the column up with the compressed helper springs it looks like there's really no difference at all or minimal. Maybe I'm missing something? But there's clearly some extra suspension height in this new arrangement.
On my Penske's (on my Lotus), I adjusted the compression to 'more stiff' and it helped not bottom out on big bumps (made it smoother) while making the normal road a little bit more rough. My suspicion is that it's not a binary switch, and every high speed bump has some component of a slow speed bump.I just heard something from KW. The adjustable compression/rebound on coilovers are “low frequency”, mainly about weight transfer in corners. The daily comfort is more about “high frequency” compression/rebound, which is not adjustable and not changing when you adjusting the low frequency ones.
I'm currently in the process of installing this MPP kit for a customer's vehicle.
Dfwatt, I've encountered the same issue with you; front jacked up high, rear was lowered. I found on the first post of this thread that the alignment dowel was ground down, I'm going to go back out to the shop & check if that's what's causing the issue with the front of his car being so high. I have about 1/2 to 3/4 inch of thread remaining on front shock body before the lower spring perch bottoms out but my concern is this: having the spring perch so low, doesn't that drastically effect spring rate?
I've installed many coil over kits on other vehicles & do a lot of alignments oriented towards road racing. Most other kits set pre-load, and then height is adjusted by adjusting shock body length. I'm concerned with dropping the lower perch in the front all the way down we are now losing spring tension. I'm going nuts over here, have just about every suspension component loose on my alignment rack thinking that some suspension component is applying pre-load but that's definitely not the case.
I don't believe that the spring perch height per se effects spring rate. The spring has to be compressed a certain amount by the roughly 1000 lbs it is carrying. That's constant. The only difference is where that several inches of compression places the overall suspension - the spring perch adjustment controls that.
The more I think about this though, the more puzzled I am. The difference between the aluminum top column and the helper spring can't be more than a half inch, but the suspension sure seems to think otherwise. View attachment 425437
Compare that with the original helper spring, which sat on the bottom of the coil instead of the top - click this link below for the image.
https://i1.wp.com/www.mountainpassperformance.com/wp-content/uploads/2018/09/Front-Coilovers-Installed-With-Brakes.jpg?zoom=2.4750001430511475&resize=1080,675&ssl=1
It just doesn't add up? We are missing something here.
Is the bottom of the damper fully seated into the fork?
Going to check
When the damper is seated correctly into the fork, the welded on stud will be almost touching or touching the bottom of the guiding slot. This is why you would need to clean up the weld around the stud so doesn't get in the way.
