GreenHokie
I just drilled a hole either side in the frunk cover and then blanked with easy to remove grommets.
View attachment 635956 View attachment 635957
OK. You’ve inspired me. I’m going to drill mine this weekend!!
Had my local shop drill just above the damper housing and they gave me a rubber grommet for it. Works like a dream to not have to remove the frunk housing each time!Where did you get that neat little cover? This is clean.
Awesome, enjoy! I am running 12/10 right now during the winter since I won't be carving any roads anytime soon.Spent some time dialing in ride height a bit today, I took the center caps off and used a tape measure to hook into the top of the hub and measured to the fender from there. With the Performance wheel design I put it in Tow mode and rolled it back and forth until it lined up to get a uninterrupted vertical measurement. Also took the time to change to 8/10 on all the dampers and took it for a quick spin on some back roads. I giggled a few times. Getting it aligned Tuesday at my buddies shop, didn't get any of the rear arms but need to 0 out toe.
Looks good. Did you use the height setup measurements from MPP?
The Sports kits are in stock now!!
We will do our best to keep it that wayI'm just waiting for my EV rebate checks to come in before I buy! Hopefully next month there's still plenty of stock.
Looking real good Eddie! You move quick hahaI was able to have my MPP Sports installed today and all I got to say is WOW!!!! I cant wrap my mind around how I can lower it this much and it still more complaint than the stock suspension.
The roads are uneven and filled with cracks in my area making the stock suspension feel very nervous. Now I barely feel the cracks. I can tell the suspension is more firm but it sucks up the road imperfections. Steering is tighter now too. I couldn't be happier with the results. The staff at MPP is awesome. I purchased the coilovers while on deployment in NOV and got extend until MAR . They honored their black friday sale and held onto my order until I returned home. Awesome product and company to match.
View attachment 647421View attachment 647422
Congrats Eddie! Your car looks great. We might be on similar trajectories. I got the Sports coil over kit then all the suspension arms and then the front lower control arm bushing. At each stage of build out the turn in got sharper. One thing you might think about is getting some lightweight forged wheels and when those P Zeros we're out getting the Michelin Pilot Sport 4S. Handles better and rides better too.I was able to have my MPP Sports installed today and all I got to say is WOW!!!! I cant wrap my mind around how I can lower it this much and it still more complaint than the stock suspension.
Adjust for softer compression/rebound by turning towards the Minus sign which is higher numbers. Smaller numbers are stiffer but better for handling. Currently at 10R/12C, 7-19-20 (my soft settings). For twisties, 8R/10C). Rebound at the top, compression at the bottom.I might me over thinking things here but on the rear suspension + and - shows opposite on rebound (+/-) and compression(-/+). On the instruction video mountain pass puts out they say stiff is clockwise and soft is counter clockwise.
So I am asking this newbie question. The - rebound =soft and + compression = soft?
Thanks make sense. I got to redo my settings. My compression is turned from full soft. I had turned them the same direction as rebound.Adjust for softer compression/rebound by turning towards the Minus sign which is higher numbers. Smaller numbers are stiffer but better for handling. Currently at 10R/12C, 7-19-20 (my soft settings). For twisties, 8R/10C). Rebound at the top, compression at the bottom.
Clockwise or counterclockwise depends on how you look at the shock. Just follow the + and - directions.View attachment 648417View attachment 648418
