Where does it say they wont. The speeds aren't even as high as normal driving on the autobahn.
My gosh man.
You keep bringing up the Autobahn.
It's irrelevant.
Do they put VHT on the Autobahn?
Does VHT provide traction and tire grip beyond what would be found on a typical street surface?
Yes, VHT can damn near take your shoes off if you walk across a racing surface with it on it.
So if you were to start having drive train trouble after hard launches on a VHT prepped surface, what the hell has that to do with the Autobahn?
Should a manufacturer be required to cover drive train issues after you've done countless full power launches on a VHT prepared racing surface?
You think they should? Go ahead, bust something cutting a 1.50 or even better 60ft time and try it.
Do people do launches in the middle of the Autobahn after the Autobahn has been sprayed with VHT?
It's clear that if you learn, it will have to be the hard way.
You realize that "drifting" is not racing, but one can have a warranty repair as a result of doing it to "test" the vehicle, denied.
But again I say, I ain't the one you'll need to convince.
If you're talking an untimed event, such as an HPDE, then you may have a leg to stand on. Some call it driver education.
But a timed event such as a quarter mile pass? Well I hope that you never find yourself having to fight for a warranty repair for a mishap which occurs on a drag strip.
I said "racing tends to break things" and you asked"who's racing?"
Well let me clarify. Driving to extremes will usually expose the weakest link.
If you happen to expose one while on a drag strip, and it's discovered by the manufacturer that this was the locale where you discovered it, well then good luck convincing them that you were not racing while you were on that drag strip.
