St Charles
Tesla, not TSLA!
hmm. I might try to join you if I don't go to the Tesla hearing in Richmond that day.
Thanks! I would appreciate the company.
Right. That's what I said /s. But let's not drop into internet rage arguments. It seems you are upset about this and I'm really not interested in and emotional discussion here. I'f you would like civilized discourse we can continue.
Could some of the 2016 P90D owners with the 500+ Kw batteries please post some reports below 90% state of charge? We would like to see how much the max power levels (with and without Max Batt Power) are reduced around the 80%, 70% and 60% levels.
Thanks!
uhh...Yeah, they do. All the time. Racers need to know this information in order to be competitive and posers use it as an excuse for why they suck at the track. There are several websites that even help calculate these corrections(Let me google that for you). I'm not sure you are aware of just how impactful heat, humidity and air pressure affect the performance of an ICE.
Picked up my new P90DL on Sunday, 6/26. I'll try to get some measurements.
My battery is # 1088792-00-A. Is there enough data yet to guess if that's a "new-better" battery or one of the suspected "newer-notBetter" packs?
Also, for those of us new to this... what EXACTLY should we do with PowerTools? get to 90% SoC and MaxBat ready mode and then drive around with it in Tracking mode and do some 0-60, 0-180, 30-80 runs? drive around mashing the petal as often/long as we can?
Not a joking question... would be great if someone can post a little guide to how to set powertools and what kind of driving runs should be done/recorded.
thanks,
-josh
Thanks Alex. Got powertools and will try to add some data.
You just start powertools into "tracker" mode and do runs? (As opposed to the "0-60 timer" mode?).
My biggest problem is finding a safe road to do this.@JoshG Here's what I do when logging with PowerTools. Someone can correct me if I'm doing something wrong.
Note: It is recommended that the car be in motion during app startup to speed up the connection and startup time. Also, make sure you are not on your wifi network if you are near your home or office, etc. because if you start while on that network, once it disconnects from the network that session will be automatically terminated.
1. Start the PowerTools app and make sure it's on the "Run" tab in the lower-left
2. Click the Start button in the upper-left
3. Select Vehicle Tracker (highlighted below) from the pop-up menu
Note: The 0-60 mph Timer just allows you to time one 0-60 run and it automatically begins once you come to a stop (0 mph) and the session automatically ends once you pass 60 mph. This mode has been flakey for me. I have a question in to the developer. I'm having some date/time stamp anomalies which might be causing my issues.
Once Vehicle Tracker has started it will log speed, power, elevation, SOC, odometer, range, and heading. On the screen above, the background of the displays will turn green letting you know it is recording. The top 2 will show the current speed and power and the bottom 2 will show the max speed and power of this session.
I like to start with 100% charge and max battery ready and run various tests like 0-60, 20-80, 40-100, 60-100, etc. You can also try a variation of each of these with max battery off and at various states of charge. I've noticed that I often lose traction when testing 0-60 which hampers my power so if I start from 20 or 30 mph I can actually get a higher power output. Some also turn off the AC during these tests to maximize power.
Once you are done, just click the Done button in the upper-left (where the Start button was). Then you can go to the Log Files tab at the bottom, select that session, click the "Load for Plotting" button in the upper-left, go to the Plot button at the bottom, select that log and choose the Plot Type (speed, power, etc.) to produce a graph of that session.
Hope that helps. Good luck and be safe!
Geez. I know da calculations very well. I was trying to tell you that on the drag strip (unlike the forums) you can use the da calculations as a tool but you cannot claim that you would may potentially have ran a 10 because the calculator said so.
The good thing is that these ice have an option to use the calculators as a tool but also go to the track with preferable conditions and run said/calculated 10.
Where do we go to run advertised (tesla) or potentially corrected (motortrend) 10?
Alex
41% SOC, Max battery ON, 424kw
I'm wondering what changed between faster battery 1: 1071394-00-A and newer fast battery 2: 1088792-00-A
I thought it was VTEC kicking in! ;-)Boost pressure...
