I don’t join Octopus until Monday but they’re already letting me schedule a chargeSwitched over to IO today and have my first scheduled charge tonight.
Just plug in. It may charge for about a minute and then stop once the Octopus servers picks up on the charge starting.
The FAQs on the Octopus website are helpful in explaining these types of Qs.
I had that problem and resolved when I reinstalled the iOS app.Interesting that I cannot get scheduled IO charging. It charges non stop and no schedule generated.
IOS IO app says that Schedule will be created once car will be plugged in.
I even logged out from android app
Io will try to reach 100% but car will not charge more than 90% what is setSecond day on IO and I’ve not driven anywhere today and battery is on 89%.
I’ve left IO enabled, 100% charge by 9:00 but car is set to 90% - same as last night.
Today at around 5pm it scheduled 3:30-4:00 and 4:00-4:30 which I found strange as it’s only 1% below desired charge level. I’ve just checked again and it’s now showing 3:30-4:00, 4:30-5:00 and 7:00-7:30.
Any reason why so many slots for such little charge? Also do scheduled slots change regularly? I’m not concerned about the slots within the set 6 hour window but the ones outside that window as obviously the cost difference per kWh is considerable.
It happens some times, but during those slots all household will have off-peak rateAhhh that makes sense! I remember reading on here to always keep IO at 100% and set the car to whatever percentage you actually want but overlooked the fact IO will think you want 100%.
Thoughts on the slots outside the normal 6 hour window changing? Does that happen a lot?
Are there home appliances that would even work with potential 30 minute on, then off, then on again schedules? I very much doubt that.That’s the only reason I ask lol say you scheduled your washing machine to run according to the IO schedule but that changed and you hadn’t checked again. I guess to be safe only schedule it during the 6 hour window?
Mine all run on the same cycles every time so I never program outside of 23.30-05.30, especially as they only need an. hour or two anyway.
That does seem an odd schedule. I haven't seen anything like that unless I ask for a bump charge. But yes if that sticks it should mean off peak all the way through.45% yes 7kW
But that means low rate for house all night ?
