Pink Duck
And the first 2-hour hour one at that, from 17:00 until 19:00, again at £2.25/kWh saved. Double points on offerMonday 12th now looking likely for the next National Grid ESO DFS, aka Octopus Savings Session.
I guess that was my point - being an untrusting sort of soul, is quite a leap for me to just 'believe' I'm getting cheap electricity, not only within the 6 hours, but also outside of that if the schedule makes it so...It’s hard to tell whether it is doing what it should.
I’ve recently setup IO through integration with Ohme Home Pro. Should I be doing anything specific with regards to the smart schedule on the app to ensure it is using only cheap rate? It’s hard to tell whether it is doing what it should.
To further respond.Mixed feelings if you're doing this everyday, sounds to me you would be borderline on the fair use policy with a set-up schedule to reach 100% by 4am. (unless you really do need the car at 4am?).
Unless you had a very low SoC this morning I assume you declared on IO that you had a granny charger at 10amps so the system computes : (100% - your
My first bill will be interesting
Can I ask as to the reasoning to such recommendation?I would integrate with the car in preference to the Ohme. Integrating with Ohme will allow you to use IO with other cars, but if that's not a common scenario, then I'd recommend integrating with the car instead.
Tried again. No luck. Got the following message from Octopus:Close the app and force close it, wait a minute or two, then try again. Can get a bit nervous/twitchy during the disconnect/reconnect part.
