SageBrush
REJECT Fascism
What is your definition of reasonable emergency braking?
You are missing the point. There is no definition, there is only what you are willing to accept
Summer tires turn into hockey pucks below 55 degrees, very dangerous to drive even in dry or wet conditions.. The wheels to a massive impact and absorbs the impact and the body was not damaged, I would strongly suggest as the poster suggested to get the suspension checked out,, you can clearly see based on the impact how fast the driver was going on a slick/frozen tires..
Here's a better view of the OP's tires:I just need to know whether OP was really driving in the snow on summer tires…
Def a good “zoom and enhance” analysis.Here's a better view of the OP's tires:
View attachment 877566 View attachment 877567
Obviously Pirelli, but are they Sottozeros? No, based upon the tread block appearance, the block spacing is not wide enough, and the blocks aren't tapered enough to be the Sottozero.
Plus, the bottom image shows the tire size, and the Load rating of 92Y, that makes it the P Zero, as the Sottozero is a 92W.
@ay221 correct
I drove summer tire on my Porsche only when it was above freezing, but you do lose traction so had to be careful when making turns.
When I had I didn't drive it below freezing to avoid damaging the tires. On my M3P I got the performance all-season, but use another car with Nokian HP10s for bad winter weather. If I only had the M3P it would have at least winter tires.@ay221 correct
The argument goes back to several things.
1. Drive within your limits
2. Ensure your vehicle has what it needs for the conditions.
3. DON'T push it.
Not directed at you @ay221 but tires have limits. For us Coloradans....things change on a moments notice. I know EXACTLY the date the OP had the "incident".
Just be careful and if you want to "chance" things on a drive that makes you uncomfortable for your vehicle or your abilities just stay home.
We own 2 P cars......I will NEVER take my track car out if there is precipitation in the fall/winter/early spring. When it is "nice" I will definitely "exercise it" after a tuning session but will NOT take it out in the conditions shown.
The OP learned a valuable lesson that the community can take advice from.
Personally Tires and Driver actions were a combination for a failure.
or just go SUPER slow if you absolutely *have* to drive... in the OPs video I see a car on summer tires and solid snow covered street "flying" downhill on a residential street...When I had I didn't drive it below freezing to avoid damaging the tires. On my M3P I got the performance all-season, but use another car with Nokian HP10s for bad winter weather. If I only had the M3P it would have at least winter tires.
I don’t think suspension components get “shifted” in a collision, they get bent. Michelin web site says the Pilot Sport 4s are ok down to zero degrees Fahrenheit, although snow is probably a no go.Great first post with dashcam and everything! Welcome!
Yeah, a bunch of suspension components likely shifted, no big deal for an alignment shop to reposition. Those wheels are pretty damaged and possibly bent, consider buying a used set of 4 for ~$2500 from the classifieds here or from Facebook.
Grinding might be something simple like a bent brake rotor shield, or maybe you damaged a wheel bearing? Either way it's a few hundred bucks to fix.
And btw, if you think you should wear a jacket, don't drive on those summer tires. I don't need to tell you what could happen when summer tires get cold.
So in the PNW (Seattle area) the temperature is often below 55 and raining. Typically from November to April you’ll experience temps below 55 and often times raining. Are you suggesting that “summer tires” can only be used in our area when the temperature is above 55 degrees?? That would also mean most of Europe. Typical bad internet advice on your part. Please show me where Michelin PS4s cannot/should not be driven below 44 degrees.Summer tires turn into hockey pucks below 55 degrees, very dangerous to drive even in dry or wet conditions.. The wheels to a massive impact and absorbs the impact and the body was not damaged, I would strongly suggest as the poster suggested to get the suspension checked out,, you can clearly see based on the impact how fast the driver was going on a slick/frozen tires..
Hi Everyone,
Here is an update on repair costs if anyone is interested.
