P100D on the Dyno....
Discussion in 'Model S: Driving Dynamics' started by fiksegts, Feb 20, 2017.
  1. fiksegts
    fiksegts Active Member
    Miami
    • Like x 5
    • Informative x 4
  2. BrokerDon
    BrokerDon Member
    Newport Coast, CA
    920 ft. lbs of torque
    589 hp
    ... on the 9th full power run.
    CRAZY numbers.
    Congrats Tesla engineering team for an INCREDIBLE job !!!
  3. TSLA Pilot
    TSLA Pilot Member
    United States
    Brooks,
    Could we bother you for your battery part number, just so we'll know which batteries provide the power you log on the dyno and the acceleration you show on DragTimes videos?
    Those of us with P90DL's want to keep track as we upgrade to P100D's, just in case there ends up being more than one version.
    Thx.
  4. fiksegts
    Miami
    1086755-00-D
    my friend took delivery of a new P100D AP2 car a couple weeks ago and it has the same battery...
  5. R.S
    R.S Member
    Munich, Bavaria, Germany
    The hp number is actually kind of impressive, from a Mustang dyno. For bragging rights you could go to a Dyno jet, they put out higher hp numbers.
    If I were in the business of designing dynos, I'd just print out 20% more power than measured, mine would definitely be the most used! :)
    • Funny x 2
  6. sdorn
    sdorn Director of Awesome
    Georgia
    I used to spend a lot of money having my cars modified and had dyno runs done on my cars dozens of times. The HP and torque numbers from any particular dyno, regardless of manufacturer, are mainly only good for comparison against other runs on that same dyno. Dynos use all sorts of adjustments when calculating HP and torque including for things like temperature and altitude. It is very easy to manipulate the numbers by tweaking these variables or by changing the actual testing conditions. Add to that every manufacturer uses different methodologies and technology (e.g. some dynos apply braking force to the dyno wheels to simulate resistance from wind/road surface and others use a free spinning dyno wheel where only the inertia of the wheel itself provides resistance). You end up with completely inconsistent measurements from one machine to another.
  7. n2mb_racing
    n2mb_racing Member
    durham, NC
    While this does seem awesome, was there an RPM pickup on the motor? I'm guessing that wasn't possible. What do the torque numbers mean without RPM? Sure, we expect torque at the wheels to be huge, due to the gear ratio, but I think it needs to be corrected by RPM to be comparable to an engine torque figure. Even then, I'm not sure we can directly compare this number to any ICE car...
  8. bishoppeak
    bishoppeak Member
    San Luis Obispo, CA
    I'm no pro at this stuff, but I think torque is torque regardless of RPM. In an ICE you need RPM to derive HP from the torque reading.
  9. R.S
    R.S Member
    n2mb_racing is right, without the motor rpm you can only measure the torque at the wheels. You use that and the rpm of the wheels to calculate hp. Actually their torque number seems way to high, just from looking at the dyno chart, you can say, that they made a mistake, torque seems 50% too high. That's why I don't care about EV's torque numbers anymore, almost nobody gets it right, especially not the tools that own the dynos. Hp it the important factor here and 580 is impressive.
  10. n2mb_racing
    n2mb_racing Member
    durham, NC
    Thinking more about it, the torque could really be any number. If the motor turned at 200,000 rpm with a really high gear ratio, the motor shaft torque might be really small, yet still develop lots of HP and torque at the wheels.
    Maybe torque for ice engines was a reasonable metric since they all turned about the same speeds.
    Anyway, I'm going to guess it is not that far off, since I think the motor spins at 15k rpm max, so maybe twice the gear reduction of an ICE?
    Either way, it's impressive and damn fast.
  11. scaesare
    scaesare Well-Known Member
    NoVA
    If it's a single fixed gear ratio without any clutch or torque converter to allow for slip, then don't we know all we need to know?
    I believe the gear reduction is ~9.7:1
  12. WarpedOne
    WarpedOne Supreme Premier
    Slovenia, Europe
    No.
    We do not know the fudge factors the dyno uses to cook the Engine power and Engine torque values.
  13. David99
    David99 Active Member
    Brea, Orange County
    Torque is the rotational force. That's what any dyno measures. HP is calculated using the measured torque at a certain RPM. So in order to get correct HP numbers the torque has to be correct.
    HP really isn't the right measure for a car. Torque is. Torque is how strong the wheels spin. That's what makes the car go.
  14. WarpedOne
    Slovenia, Europe
    Both numbers are important. Problem is the industry got used to reporting torque at some RPM of the engine.
    What is really meaningful is wheel torque at different speeds. That is what you feel in the car (adjusted by car weight).
  15. scaesare
    NoVA
    Well, you don't know those regardless of what you've strapped to the dyno.
    My point was that it was mentioned above that they didn't capture engine RPM. Given a single fixed gear ratio, we can derive that from wheel RPM.
  16. David99
    Brea, Orange County
    True the car's weight makes a big difference. What matters is acceleration. That's what you feel. 0 to 60 in 3 seconds is an absolute value. 600 HP without the car's weight doesn't tell you anything about how quick it is.
  17. Pezpunk
    Pezpunk Member
    Bristow, VA
    well, there are Diesel-Electric locomotives with upwards of 6500 horsepower but they can't do a standing quarter mile in under a minute.
    traction and gearing seem to be the limiting factors, though. put some racing slicks on the thing and it might get interesting.
  18. R.S
    R.S Member
    Yea but they "measured" 920lf-ft of torque, which can't be at the wheels, or it would take some 14 seconds to get to 60, nor can it be at the shaft, otherwise power would be higher.
    They measured peak torque at 50mph, which, knowing that the motors spinning at about 6800 and 7000rpm at 60mph, is at least 5600rpm, so power would be more than 970hp. So 920 lf-ft is just wrong at either the wheels, or at the shaft.
    Knowing that an electric motor has a flat torque plateau until peak hp and then a hp plateau(not exactly flat but relatively), hp is a lot more useful number than torque. The Model S motors aren't that torquey, but because they can hold peak torque to a relatively high rpm and rev really high they can be geared really high, which makes them great for acceleration.
  19. Pezpunk
    Pezpunk Member
    Bristow, VA
    wat
  20. David99
    Brea, Orange County
    A dyno isn't all that complicated. It's a large and heavy drum. They measure the rate of acceleration of the drum which let's you calculate the power very straight forward. It's really simple math. By default, that's at the wheel.
    If you put the car in N (neutral) they can also calculate the losses on the drive train up to the clutch and subtract that. That's how they make statements about power at the wheels vs at the shaft. (Since the Tesla doesn't have a clutch, you would be able to calculate the losses in the reduction gears and be able to make a statement about how much power is at the motor).
