TonyT
Also found a way to make the adjustable headrest work without the UI. All you need to do is install a diverter switch from the up/down lumber motor wiring. When you click up on the lumber support the motor will drive up and click down will drive it down. Use the switch to pick between the two (lumber support vs headrest). The only thing to watch for is that put the switch back to lumbar before exiting vehicle (memory module for seat settings)
Interesting, I was planning to add a separate switch for manual headrest control so no one accidently leaves it, and it's rarely used. How did you switch lumbar from 2 to 4 wires, or did you use nextgen controllers?
