I thought about this, and I took a piece of the framework that I had broken off to my heat gun to see what it would take to loosen it. The glue or whatever it was wouldn't melt. The plastic housing was burning and the glue was still solid. :-\
Plus, heat + these cells scares me a bit at this point. Data I've read suggests thermal issues possible beyond 150F.
Would some kind of solvent work?
Doubtful--anthing harsh enough to weaken the epoxy is going to have a laundry list of associated problems.
wk057--are the cells potted, or just bonded at the base? If they're potted, how is the negative connection made?
I doubt a local fire department has the ability to educate such a large international group of enquiring minds. The willingness of wk to share his experiences and knowledge is really about as philanthropic as science gets. We aren't getting the abridged edition, we are getting the moment by moment update. He is giving us the nitty gritty details just because he wants to, I think he can handle his project without giving cells to the fire department. obviously any fire department could benefit from the knowledge obtained from testing, but when was the last time you followed a fire department blog
I may contact the NFPA about it and see if they want to do some testing/experiments with it if I can't find anything else to do with it.
I'm not the person to ask that question and expect the answer you're getting. I'm regularly speaking to various first responder communities on how to deal with these situations, especially local volunteer fire departments.
The point wasn't that he needs to give them to fire departments, but rather if he's given up on extracting cells and has a damaged module, he has an option to donate it to a local fire department that can do training (similar to how we use dilapidated homes for training exercises). Of course, if there are better uses, then he does have a right to put them to use. I was thinking they could create true runaway by purposely damaging some cells and applying flame-o-matic.
I work at BatteryMarch Park in Quincy, which is a complex of buildings where the NFPA's headquarters are located.
One day, the head of the NFPA's Head of the "Electric vehicle safety program" was waiting for me by my Model S, he wanted to use my car for a photo op at their onsite EVSE... since then, they've also shot some promotional video of my car driving around in the parking lot. At any rate, I can put you in contact with him, if you'd like to see if they have any interest in examining/testing the remains of your module. let me know, thanks.
I live pretty close to the the Massachusetts Firefighting Academy: The Massachusetts Firefighting Academy (MFA)I work at BatteryMarch Park in Quincy, which is a complex of buildings where the NFPA's headquarters are located.
I finally got around to doing some testing of the cell level fuses using a power supply and my DC electronic load.
I was able to get them to carry 24A for 60 seconds+ and they would consistently pop within a second or two at 25-25.5A.
Honestly, that's more power than I had figured they were able to handle. Assuming they're sized for 25A, that's 90W per cell, almost 40kW per module, or close to 8C max before consistent popping.
Using an NEC-style 25% margin gives me a constant current draw of about 19A possible before popping fuses. That'd be about 6C, or about 485kW nominal for an 85kWh pack.
This could explain the reason the P85D doesn't show 691 HP (515kW) under full acceleration. However, that's speculation since the D variants have a different battery pack part number which may or may not have larger fuses. No way to know for sure until someone tests the fuses in one. I believe the full 515kW+efficiency losses could be pulled from a fully charged pack for a very short burst, though.
Edit: It's worth noting that the primary goal of these fuses is likely simply to prevent a single cell with an internal issue from destroying the rest of the cells, not to protect against module max current draw. Let's say a single cell developed an internal short. The other 73 cells in that set would then be sending all of their power through that cell, since they're in parallel. With the fuses, the fuse would just pop under the hundreds of amps available, and barring any thermal issues related to the bad cell, would save the rest of the cells.
I think it's a fair assumption that some fundamentals have changed with E and F packs. They are able to sustain higher current draw for longer periods not just while flooring the accelerator, but also while supercharging. I suspect the individual cells have been upgraded as well.
Did you test the fuse while still attached to the bus bar?
Ie, one lead attached to the end you cut carefully from a cell
the other lead clipped to the bus bar
I don't agree with this assessment. In fact, my analysis of the P85D performance and charging shows almost no difference in charging, voltage drop, and only ~390kW peak draw from the pack, for only a very short period (at full charge) [~370kW at 70% charge]
That's only ~16A per cell for ~5 seconds, and it quickly tapers to half that, and even lower. This is easily sustainable by the existing cells.
If anything the only difference between a D and an E is the wiring for the front motor, perhaps upgraded connections.
I'm amazed the fuses were so precise and consistent in their behavior.
Actually, I found a fuzzy pic from my P85 showing 257 out of 264 rated miles, which would be ~97% showing only 6kW vs 18kW on the P85D.
