Awiner
Camber arms are the only way to dial in each side the same and will provide a huge range of adjustment vs static shims.
I disagree as to "sensitive to this" doesn't mean they are defective.I know you’ve read this a dozen times…. if you set the toe slightly positive it will counteract the suspension’s tendency to toe out drastically on launch which, combined with negative camber is what stresses the tire.
Yes, the Michelins are more sensitive to this, doesn’t mean they are defective…
LmaoI have multiple suspension upgrades and 3 different sets of 19" and 2 different sets of 21" ... My issue is that I like to watch the tires evaporate in clouds of smoke as it's sliding around. These are the current 19" on there, about 1.5 pounds lighter than the OEM 19 with the aero cover removed
Apologies if you’ve posted, what are your rear toe settings?I disagree as to "sensitive to this" doesn't mean they are defective.
We're talking about an OEM installed tire that in seemingly every case is literally coming apart at the inner sidewall, a nearly impossible place to notice a tire coming apart.
The Pirelli's mounted on the same Plaids, but with the 19" wheel, have next to zero failures.
Yes, it's a taller sidewall, but the forces are the same, no?
Michelin needs to recall these tires ASAP and get a new tire designed, designed for Tesla's level of acceleration/loads, STAT.
Someone is going to get hurt, eventually.
According to the Tesla Service Center, all settings are at factory spec as they demonstrated to a Michelin Field Engineer. To my knowledge, nothing came of it however as it appears they’re still selling the same tire to Tesla?Apologies if you’ve posted, what are your rear toe settings?
Tesla do not set up the cars properly from the factory.I don’t believe it’s necessary so I won’t, but if it feels like I’m having an alignment issue or seeing irregular wear then I’ll do it and contact macsboost and let them know about it
I have to get an alignment about every 5-6 months no matter what. Just had the summer one done yesterday. People are having difficulty understanding the level of force and stress that occurs on a near-5000 pound car with 1000whp. This is not a Hyundai Accent where the alignment will last 5 years.Tesla do not set up the cars properly from the factory.
It is very probable that the car is out of spec even before mounting the spacer/shim.
Correct Toe is very important to tyre wear so anyone need to check an S after delivery.
Reducing the high negative camber is not a bad thing, but togheter with a bad alignment (mostly the Toe number) the car still can destroy the tyres.
If you aren’t going to listen to or understand any of the conversation here… then good luck in your crusade.According to the Tesla Service Center, all settings are at factory spec as they demonstrated to a Michelin Field Engineer. To my knowledge, nothing came of it however as it appears they’re still selling the same tire to Tesla?
I'm still waiting for him to show me a single person that has had shims or arms installed and had an alignment (obviously not at Tesla) that are having this issue.If you aren’t going to listen to or understand any of the conversation here… then good luck in your crusade.
There are examples. I posted one of a model x on 22" pirelli with the identical problem. You can also scan back a few years and see the previous model S had similar issues.You would also think we could find examples of other tires having this same problem if it were just an alignment problem and had nothing to do with the Michelin tires.
Seems to me it's probably a bit of both. Bad stock alignment settings, lack of adjustability, and a model of tires that are vulnerable to the alignment.
Do you have any examples of a Palladium S showing this issue on any other tire?There are examples. I posted one of a model x on 22" pirelli with the identical problem. You can also scan back a few years and see the previous model S had similar issues.
The only difference now is that it is pronounced significantly more because we're running 300+hp through each individual rear tire.
Yep, the stock alignment may not be ideal, but pretty much every other wheel/tire combo on these cars shows normal wear. The 21” Michelins appear to be particularly sensitive.You would also think we could find examples of other tires having this same problem if it were just an alignment problem and had nothing to do with the Michelin tires.
No because the tire size is weird and no one uses much else other than the PS4S.Do you have any examples of a Palladium S showing this issue on any other tire?
I can say on my factory alignment with 20” all seasons on my plaid, the wear is completely even 11k miles in. And I do drive it pretty hard.
I agree with this statement. On acceleration, the car will naturally gain negative camber and toe out more. The advantage of more toe out is better turn in, and more negative camber will give it more cornering grip. Both of these are advantages at the limit of the car on a road course race track. If you can drive the car at the limit, this will gain you a few tenths in lap times, if you are truly an expert driver. The downside of the factory settings is obviously tire wear.Camber by itself will induce normal camber wear. It’s the negative dynamic toe in addition to the camber that shreds the tire.
They will hold up slightly better because those falkens are much harder, which means they slide more and wear less.Since I've owned my 2014 Performance+, both sets of Michelins have failed this way. They showed even tread wear. The part of the tire that delaminates never even touches the road. Running Falken Azenis now, we'll see how they hold up.
