We are contemplating replacing the wife's 2019 eTron with something else and one of the vehicles on our radar due to their lease deals is the Rivian R1S. Motor Trend has an interesting article about Rivian owners wearing out tires in as little as 6k miles and flagged the below issue as the likely cause. Wondering if driving in the lowest mode is causing the same issue with the MSP?
When the Rivian’s air suspension lowers, the angle between the suspension’s upper and lower control arms changes, which alters the camber, making the tires now slant slightly inward at the top when viewed head-on. In other words, the R1 can be mildly stanced from the factory with negative camber. This means that in Conserve mode, it’s putting all its weight on one edge of the tires. The inside edges, in fact, which means you can’t readily see the wear. Driving around in Conserve mode the majority (or all) of the time is what wears them out.
