This is probably the wrong thread for it, and likely deserves its own poll... But I *do* think I'm suffering from a slightly loose/vibrating drivers side mirror. I've seen this mentioned before, so it may also be a somewhat widespread issue. In my case I think it is the mirror itself, not the mirror housing, that is vibrating.
It could mean that you have worn the half-shaft joints in the low position and moving to the medium position moves to a different section of the joint. If that is the case the vibration would likely get worse as you drive more miles on medium.
I had a loose drivers side mirror on my MXP (was delivered that way). Was into service twice and each time they said they fixed it but did not. I finally fixed it myself. The front screw holding the mirror in from the inside was simply loose about 7 turns. It took me 5 minutes to fix it and it's been tight and vibration free ever since.
Awesome. How do you access the screw?
Was your entire mirror assembly loose or just the glass? My mirror glass wiggles.I had a loose drivers side mirror on my MXP (was delivered that way). Was into service twice and each time they said they fixed it but did not. I finally fixed it myself. The front screw holding the mirror in from the inside was simply loose about 7 turns. It took me 5 minutes to fix it and it's been tight and vibration free ever since.
Hours of wasted time just to experience gut wrenching frustration when all it took was 5 min with a screwdriver.I had a loose drivers side mirror on my MXP (was delivered that way). Was into service twice and each time they said they fixed it but did not. I finally fixed it myself. The front screw holding the mirror in from the inside was simply loose about 7 turns. It took me 5 minutes to fix it and it's been tight and vibration free ever since.
The entire assembly. That said the mirror cap pops off. I'll try it today and see if the mirror itself has fasteners that can be loosened.
Thanks! I do have the free subscription to the service manual, so I'll have to take a look.I checked the service manual. The skull cap won't get you access to the mirror itself. The mirror is held on to the articulation actuator by 8 clips. It's either the mirror itself that is loose because of the clips or the two axis motorized actuator. The only way to tell is to pop the mirror off the clips and check the motorized mount for looseness otherwise it's the clips.
I strongly recommend getting the free subscription to the service manual so you can check out the procedure and decide if you want to try it.
So, has anyone on this thread received .36 yet??
Any change in the vibration with the update?Yes, finally received 2022.36.5 the other day - after being forced to rock the .24 update with that stupid squeal sound for months. Finally.
I have not had any vibration in 5 months, so something went right over time. Thankfully!Any change in the vibration with the update?
What did they do to your car?I have not had any vibration in 5 months, so something went right over time. Thankfully!
The odd thing is software updates solely, and it went away some four months ago. That is the only thing I could think of, and still can't figure out why and how it went away. I watched it like a hawk and stopped asking since it disappeared. Maybe the 20" forged rims and Michelin tires (now that is a guess).What did they do to your car?
Good to hear! Anyone else with .36?The odd thing is software updates solely, and it went away some four months ago. That is the only thing I could think of, and still can't figure out why and how it went away. I watched it like a hawk and stopped asking since it disappeared. Maybe the 20" forged rims and Michelin tires (now that is a guess).
Honestly, I’d expect it to never be solved with this model. If you don’t want a car with this vibration, I highly suggest a different manufacturer.Does anyone have any indication if a fix is coming soon for the acceleration vibration? Tesla is threatening to cancel my order because I’ve been postponing my MSLR delivery for months now due this. I’d hate to loose my place in line and my deposit, although I’d hate more to spend a big chunk of change on a car with an annoying vibration that can’t be resolved.
