Powerflux
Funny that you bought the same Biltema panel clip tool as I did
The Power Liftgate has worked flawlessly for 90 days now and I use it a lot! Initially it would start to close just when it hit fully open and would also slam shut quite hard. I reset the system by holding the button until a loud beeb sounded, then pressed the button again to cycle through a full motion!
This completely cured the problem and it stays open like it should and slams shut with the force I would use to manually make the lock latch properly! With a window or door open, it slams a bit harder but nothing I`d worry about!
I have to say though that except for my 1973 Toytoa Coraolla, no other liftgate have required more force to latch properly
