Why would a child that small ever be allowed to climb into the drivers seat without the parent / caretaker either already in the car, or getting in right after them
What reason is there to do that, with the parent there? If someone wants to say "this could happen when the parent is not watching" ok, yeah children can do stuff...
very remote use case of a toddler not buckled in, freely roaming the cabin or having easy access to the driver seat, getting into the driver seat foot well, applying just the right combo of brake + stalk + accelerator, all within a second or two
that someone can now freely let their toddler climb all over the car unattended just because you have set PIN to drive.
If you toddler can execute all of the above movements in the right sequence, and can open the driver's door, and you leave him/her unattended to do all of the above
A specific case I have mentioned above: One parent goes into a store. Car is parked outside. The other parent stays behind in the front passenger seat, with their toddler child (with phone key in purse or pocket). We have been conditioned in this case to think that when we are watching the child, and there is no "key" in the ignition, the car will not go. There is simply no way for a child to turn on the car and shift to drive in any reasonable timeframe (and in some cases, it is not physically possible due to distance from the brake to the shift lever).
They get toddler out of the car seat. The toddler wants to roam around the car. The other parent doesn't think this is a big issue, child transitions to the driver seat and is happy. Supervised. Toddler suddenly slides into the footwell. Parent scolds child, reaches over to grab child. Child flails, kicks brake, and either the toddler or the parent hits the shift lever down, shifting the car to Drive. The child then kicks the accelerator. Off the car goes. Who knows where it will go...
This is a case where a fairly well supervised child (not perfect, mind you) could recreate the situation.
Is this that probable? No, not really. Could it happen? Is it conceivable? Yes. Will PIN-to-drive eliminate all potential risk in this case? Yes.
If you're still concerned about this scenario then you should use the keycard.
The particular post you quoted from me is not quite correct - there is a "gap" in PIN-to-drive coverage, though obviously not significant (due to the other things required with PIN-to-drive). If the door is closed, AND the toddler knew your PIN, they could crawl down, press the brake, go up, type in your PIN, slide back down, and then follow the standard sequence. I think that is possible, anyway. If the driver door is open, this will
not work. Obviously, the probability of a toddler both memorizing your PIN and following this exact sequence is dramatically less likely than the probability of a toddler driving the car without PIN-to-drive.
I actually think you fail to see the larger discussion. We all agree we want a safe car and don’t want to be run over, we just disagree on the required lengths to get there.
We all fall somewhere on a spectrum in this debate. You are clearly on the more precautionary side of the spectrum than I. I choose to maintain more convenience and instead opt to apply other safeguards...yet that’s inviting murphy and leaving a loaded gun laying around the house. That’s fine.
However, when I jump further towards precaution on the spectrum than you and suggest something even more safe than you...that’s too much!
I find the whole discussion humorous.
Ok, I understand what you are saying. I will remove the disagree. However, I think with everything, it is a tradeoff. I see a pretty clear risk when PIN-to-drive is off; it is far from minimal and I believe the Model 3 is likely the
easiest vehicle for a child to get to move. That window of risk is dramatically reduced due to the additional interlocks when it is turned on (described in prior posts) - Model 3 becomes likely the
safest vehicle in this regard. PIN-to-drive is minimal overhead for the group that has risk (especially with 16.2 which so far has eliminated the lag I was complaining about). I think the additional protection of changing the PIN every drive is minimal, the cost is very high, and the probability of compliance is low (so is unlikely to even provide the minimal additional protection you think it provides).
