ItsNotAboutTheMoney
So it is a form of a hybrid. That's all some are trying to say.
Some are trying to say more than that. Some are trying to say that "EV" should be reserved for BEVs and that you _have_ to call the Volt a PHEV because it is a PHEV.
To me there's a distinction to be made between:
- SAE definition
- term used for marketing/general purpose.
It's not reasonable, as GM suggested, to have an SAE sub-classification with vague definitions like "Acts like a BEV". It could been strictly defined based on measurables (even if varying over time) like maximum/recommended legal speed limits, driving patterns, comparable vehicle power all electric and hybrid, and supported temperatures ranges.
But, for a variety of reasons, for general use I do think it's reasonable to make a distinction between "You'll only have to burn gasoline if you use up the battery (except for self-maintenance)" and "You'll burn gasoline any time you (a) go above x mph (b) press the accelerator hard (c) want more than limited acceleration (d) run the heat".
