Which Carbotech compound are you going for?
Are you resurfacing the rotors each time you try a different pad?
XP12 or RP2. Hopefully there will be reports from other Tesla owners by early next season.
I resurface the rotor by using a more abrasive pad than the one that was used before. Typically in one of two day of easy street driving, the old compound will wear off the rotor through the abrasion. Visually the rotor will be shining and bright, the wheels covered with a heavy layer of brake dust. My street driving isn’t hard/hot enough to bed the material onto the rotor. A good test I use to check for material bedding is to spray water on the rotor. If distinct rust mark foams within 30min it indicates the rotor as clean of pad material. Rust mark would still form on a bedded rotor, but it will be faint.
XT910 has been the rear pads on my car for three track days. Two at Buttonwillow, one at Laguna this past weekend. At Buttonwillow, it was paired with XT970 in the front. At Laguna, it was paired with Porterfield R4. The XT910 actually is doing amazingly well on the rear when paired with more aggressive front pads.
