You already got good answers from
@AlanSubie4Life and
@Candleflame but I’d like to emphasize the impact hot climat has on the degradation:
Most part of your cars degradation is not comming from the miles driven.
It is the calendar that is the main degrading factor during (at least) the five first years.
Calendar aging is driven by [Time x SOC x Temperature]
80% SOC during long time during high ambient temps will degrade the battery quite some. One good thing, after the first 3-4 years the rate will be much lower.
3.45 V is about 25% SOC
3.7 V is about 45% SOC
4.1 V is about 85% SOC
If you look at the 4.1V /cell to the right, having an average cell temp in the middle between 25 and 40C put you at about 8 % loss after two years.
Having an average cell temp of 40C and you are at about 11% loss agter two years.
To both examples above you have to ad about one percent or slightly more or so for each year from the cyclic aging (”the miles”).
Three years at the middle of 25 and 40C is about 12% loss, plus, lets say 1% cyclic loss year put you at 14%.
So, does it help to reduce the SOC to 70%?
- Not much. The calendar aging Curve is quite flat between 60 to 80%.
What do help then?
- Having a low average SOC helps.
Charging in the morning so the average SOC during the night is lower, helps. The time from the charging stops until the drive should be short
-Not charging more then needed for the day (plus a range-anxiety killing margin) also helps keeping the average SOC down.
(Your car has the NCA chemistry)
