GREAT thread about calendar aging. I charge our 2022 MX at 50% nightly and use about 15-20% daily in the winter, so this should minimize calendar aging in a practical way. (Can't set charge to less than 50 and don't want to go 2 days or 50-->10 and then charge, so this is practical way of keeping charge under the 55% point.
Good plan!
I have looked at the charts in this thread and all show high charge AND high temp is a bad thing for capacity loss. My question is the Preheating for Super Charging that takes the battery to the dreaded 50degC before even start charge. We live in the cold for winter where it is -20C in the mornings lots of time. I remember reading how fast charging under 10C is BAD and the car won't really do it. But warming to 50C seems like "damn the battery life, we just want you to be able to take a 250kwH rate and go about your merry way"
Research about fast charging of lithium batteries did find that preheating to 40C more or less eliminated the lithium plating that is the degrading part from supercharging.
Tesla reduces the charging speed if the battery is not fully precondituioned, this is more or less safe to say that it is made to counter lithium plating.
But somewhere there is probably a compromise as non preheated batteries will charge slower and be like a brake pad in the charging que at superscharging stations.
I always precondition completely if it is possible, if not I precondition as much as possible.
So last time I Super Charged, I tried to delay nav to the SC until about 30 minutes out. Battery was warmed from about 12C to 30C and took at 120kwH on a 150kwh charger. Charged for 6 minutes and left as we didn't need much to really get home. Battery was STILL being warmed by the car during the charge session according to the phone app and hit 42C by the time we left. Car SLOWLY used the heat into the cabin (Heat Pump car)and battery came down to 25C 1.5 hours later when got home as it was about 0C out by this time.
Is what I did better? Or should I have let the car take the battery to 50C before got to charger if nav started earlier? (and if the des was a 250kw charger, would have charged faster but I knew it was an older 150.)
Lets say the battery is at elevated temperature for two hours for a supercharging session. The end temperature will not differ much even if you do not precondition as the battery will be heated longer during the charging session.
So the real difference is about one hour before the charging session, when preconditioning before the charging. This will in general be at lower SOC, as most people supercharge from a lower level, at least not above 50%.
So by preheating you perhaps follow the read line for one hour, instrad of the blue line. The difference between the read line and the blue line is the difference in calendar aging, for a new battery (first year) we see about 5% for 10 months.
10 months is about 7440 hours.
That 1 hour of elevated battery temp will cause you 1/7440 of 5%, or 0.0007%.
Another way to see it is that 10 months of preheating would cause 5% degradation.
These 10 months of preheating would be enough for 7440 supercharging sessions.
A slightly leading question: what do you think is worse, 7440 supercharging sessions or 5% of increased calendar aging
I don't trust Tesla to not be just taking the battery as warm as possible (50C+) to minimize time at the charger, at the expense of my battery life. Less time at charger makes for good public relations (I can brag how fast it charged) and doesn't tie up a station for other Teslas, so is to their advantage. But not my batteries life???
Or: What is the ideal temp to start Super Charging at for battery life, NOT fastest charge rate?
This is a picture from a research report about lithium plating from fast charhing.
At 1C (about 75 kW charging power for a model 3/Y) we need 25C to avoid lithium plating.
Its obvious from this chart that 40C or above is a good idea if we do 150-250 kW.
I once had to supercharge in winter time with a cold battery, had no options.
The battery was some 15-20C and the charging speed rocketed to 137-138 kW more or less directly (t’was a supercharger V2 and the other 12 kW was heating).
I did’nt feel happy over that situation but I had no choise. Just took the minimum SOC to make it home.
[Edit]Maybe this picture needs an explanation. Cold be misinterpreted without any more information. The batteries cecled above the lithium plating temperature perhasps did 4000 cycles before reaching 20% capacity loss as per the picture, but at -10 or 0 or +5C the battery perhaps only lasted 40 or 400 cycles before reaching the 20% capacity loss. [End Edit]
From my guess, without having the data from Teslas compromise of short charging time vs low degradation, I guess that preheating is not a bad thing.
I am quite sure that the loss is bigger by not preconditioning.
This is one of the few things we can not read research and be sure how to handle it because we do not know how Tesla did draw the line.
Everything points to the ”should precondition” if the battery care is in the mind.
