It's not so much that the batteries don't like it. It's just that the car has a lot higher energy use for various things when it's cold. People get a little fooled looking at the display and thinking that always = miles. But that's all of the energy the car has, so that has to = heat + miles.Thanks all for your replies. Will put some of this in 5o practice but definitely seems that the batteries don't like the colder months in the UK.
There have been several threads with this discussion. If you are a person who always expects that number to equal your real distance miles traveled under all conditions, then sure, it will just be useless and frustrating and infuriating to you. So plenty of people don't want that annoyed feeling and switch to % to just not think about it. But driving distances don't relate to me in %, so that's kind of useless, so I prefer the rated miles. I just don't mind seeing that the number is always going to be higher than my real miles by some noticeable fudge factor. That doesn't bother me, so it's still useful.Yes, because Tesla uses ideal (EPA) mileage, which makes it basically useless indeed. That's why it's WAY better to use energy level (%) instead.
so switched to % right away.
, where I learned each % of charge equals about 2.5 miles at 80/90 MPH with HVAC on at 70F, and outside temps of 40/60F.
Directly from the manual:
About the Battery
Model 3 has one of the most sophisticated battery systems in the world. The most important way to preserve the Battery is to LEAVE YOUR VEHICLE PLUGGED IN when you are not using it. This is particularly important if you are not planning to drive Model 3 for several weeks. When plugged in, Model 3 wakes up when needed to automatically maintain a charge level that maximizes the lifetime of the Battery.
NOTE: When left idle and unplugged, your vehicle periodically uses energy from the Battery for system tests and recharging the 12V battery when necessary.
battery. Once this low-power consumption mode is active, immediately plug in Model 3 to prevent a jumpstart and 12V battery replacement.
Not buying Tesla’s answer.My 2018 LR says 100% is ~280 miles, usually less. It was 270 or so, but after some deep cycles and time at 100% with no drain to cell balance, I got to high 270s, 280 on some lucky days.
Tesla says this is acceptable and in fact, I was charging too much. I need to let it drain lower before charging, only cycling 90 to 80 to 90% a day was throwing things off. My multiple cycles seems to say this is BS.
Worst of all, it suddenly happened in early 2020, just suddenly lost 30+ miles after an update. Losing over 10% in just over a year was a bit extreme, but at least it's stopped. Seems like it's just software based, but still frustrating. I know, turn it to % and don't look back...but when I travel, the car's GPS is calculating 280 miles max range on a good day, losing 30-60 minutes of extra driving between charge stops. That part bugs me.
OK. Here's the range update I promised. Planned a drive from Austin to Columbus (end of Hwy 71 where it meets IH10) and back without stopping except to take photos of display. Vehicle was never in "park", only "hold" and only for a few seconds.. Had to wait until weather improved in Texas. Charged vehicle to 100%, awakened vehicle while still plugged in, range displayed 352 miles. TI mean the rated range display on the top of the screen (the battery display). Again, miles are preferred because they are known units of energy, while each % is not known (though it effectively is known for your vehicle right now based on your 100% = 353 rated miles report - but this relationship could change at any time). Not to mention the resolution difference of a factor of ~3.5.
By the way, this is another sticky with extensive info on the battery in your car, unfortunately it is quite long - but just a few caveats:
1) Lot of discussion of European batteries there - this is not relevant to the US vehicle, which only gets great Panasonic batteries with no top lock.
2) Be careful to distinguish between discussions of Performance & LR vehicles.
3) That being said, plenty of screen captures of data and constant calculations which are unassailable. 77.8kWh battery shows 353 rated miles (now) for the US LR non-P vehicle, and it charges to 77.8kWh. (Unlike the European vehicle.). You can see how this changed over time, but it is final now and will not change (of course it will go down as your battery degrades but the energy will reduce in the same proportion).
MASTER THREAD: 2021 Model 3 - Charge data, battery discussion etc
Austin-Columbus: 95 miles, 28 kWh, 295 Wh/mile, 62% of power remaining, range showed 216 miles.. Drive is relatively flat. First 30 miles traveled 60-75 mph. Set cruise control to 80 mph for about 15 miles, then lowered to 75 mph for final 50 miles. Temperature outside was 55-65 degrees; internal temp in cabin was set to 69 degrees.
Columbus-Austin: 94.4 miles, 28 kWh, 292 Wh/mile, 24% power remaining, range showed 83 miles. Drove at speed limit (no cruise control) of 75 mph for 60 miles. Drove remaining 34.4 miles at posted speed limits of 60-75 mph. Temperature outside was 65-71 degrees; internal temp in cabin was set to 69 degrees.
Total trip was 189.4 miles, 56 kWh, 294 Wh/mile. Range decreased from 352 miles to 82 miles (270 miles), battery percent 100% - 24%. No Sentry Mode, no rapid acceleration at any time, vehicle never in Park. Total trip relatively flat.
Imputed total vehicle range is 249 miles (189.4 divided by 76% usage). Total battery charge displayable is 73.7 kWh (56 kWh divided by 76%).
This is for a 2021 Tesla Model 3 Long Range (refreshed model) less than 2 months old, 18" wheels, with no Sentry Mode on and no rapid acceleration. This is 70% of advertised EPA range.
imgur.com
I've asked Tesla to investigate what could have been done to increase range closer to EPA advertised range. I've done this twice before based on stop and start driving, and each time Tesla said nothing can be done the car is operating properly.
Range was a major factor in my purchase decision. At every step, Tesla reps told me range was achievable. Even websites like Teslike.com show older versions of the M3 LR getting 277 miles of range at 75 mph. This was for the 2019 M3 that had either 310 or 322 EPA range. I assumed my worst case scenario at 75 mph would be north of 300 miles, and likely closer to 320 miles of range. Not even close.
I frankly would not have purchased the vehicle had I any inkling real world range for a vehicle advertised to at 353 miles of range would be less than 250 miles of range when brand new. Let's see what Tesla says. I can post photos of the LCD screen at departure, at the end of the first 95 miles, and upon return to Austin. Total trip time was 2 hours 49 minutes.
If you want to achieve a range closer to the EPA advertised range you have to drive more like the EPA test. i.e. drive slower.
I think overall vehicle performance is fine. But had I known range was so much lower than EPA, I would have waited until the technology improved. The Teslike.com shows a 2019 M3 LR with 310 EPA range achieving 277 miles of range at 75 mph, or 89%. With our 2021 M3 LR, that would be 315 miles of range at 75 mph. That's what I would have been fine with, not south of 250 miles of range or significantly poorer range performance from a vehicle marketed as having superior range.I absolutely agree realistic highway range on EV cars should be required, rather than the misleading way EPA does on EV window stickers. Tesla only includes their fantasy 353 range on the window sticker, but no highway one. Misleading too. Anyway, if it wasn't for this forum, I'd have been sorely disappointed too, but I knew what I was getting into, so no regrets here.
Not many companies will retain public trust by delivering 70% of what they advertise.
But they deliver 100% of what they advertised; which is the EPA test suite range. You can't expect to get the EPA rated range when you aren't driving the same way as the EPA test suite. You can even get almost 200% of the advertised range if you try.
It sounds like you are more upset at the EPA. They make the test suite and the rules that that is the range car makers have to advertise. Tesla didn't make up those rules.
I think this is related to the battery 63 kWh capacity.
Again, think the issue is my vehicle only will charge at 100% to 63 kWh, and the local Tesla service manager tells me that's perfectly acceptable for a new vehicle.
