Maximilien
Wow! Are you in the slow lane doing 55? LOL.
Nope. On highway, 65 mph~70mph Mostly. Occasionally 75-80 mph when in hurry.
As a young professional, I don't have that much of luxury in time.
I don't know if the 45 minutes is correct, but once you use up the 90 extra miles you start with, guess what happens ?I have a philosophical objection to stopping every 2 hours when driving and spending 45 minutes recharging the battery.
I would guess he understands physics and drives close to the speed limits.Wow! Are you in the slow lane doing 55? LOL.
I wouldn't compare to a P85 without regard to his tires. 21 inch rims with performance tires are a range killer.
This depends on person driving style.
My Model S says EPA 259 miles but I get nearly 300 miles.
My Model X says EPA 295 miles but I average out 335 miles per 98.4 kwh cycles..
So if EPA calculation is 220 miles. I can expect about 250 miles at least for base.
This makes the Model 3 a really good car.
You'll probably have to stop twice with the long range as well. I drive my P85D from the Bay Area to LA pretty often and I make at LEAST two stops, depending on how fast I'm driving (I5). This is with the battery fully charged when I start.
No.Sure, but that's an extra 75 minutes of drive time ...
Same here
That would be really annoying. What's the range on a P85D?
My current vehicle can make the SF --> LA trip without a stop for gas, with about 80 miles of range left. However, I often make one stop just for a bathroom break and I top up the gas in case something crazy happens at the grapevine since I'm already stopped. Still, that's like 30 minutes tops. I can live with 1 45 minute break. 2 of those would feel REALLY long as it's such a boring drive. I'd really have to reconsider taking the M3 when doing that trip then and just using my current vehicle.
I've been estimating about 5 miles a minute recharging rate, so for a 400 mile tripSame here
No.
Figure an extra 25 kWh in the LR model and a charge rate of ~ 70 kW. So you add 25/70 of an hour to equal an LR battery capacity.
On even longer trips the faster charge time of the LR will of course save more time.
Keep in mind that we are quoting worst case scenario of cold temps and higher speeds where you might get about 75% of ideal range.
More than likely with the long range version you could do the trip with a single recharge of the battery.
The p85d that someone quoted above has 253 miles of EPA rated range when the battery is new.
Takes less than 45 minutes.I have a philosophical objection to stopping every 2 hours when driving and spending 45 minutes recharging the battery.
SR: (400 -220)/5 = 36 minutes to recharge
LR: (400-310)/5 = 18 minutes to recharge
These are minimums. Add a few minutes for a buffer
I had just typed something similar to this. The only additional thing to add is that it wouldn't be two 45 minute stops even if you stopped twice. You charge faster at the beginning, so two 25 minute stops might allow you to drive faster and take the same amount of time as one 45 minute stop.
310/220 = 1.41The battery on the LR is about 50% larger than the SR model battery. If the base model would need a recharge at 2 hours in non ideal conditions the LR should go about an extra hour before recharge.
Usually about 20 minutes is best, charging in the sweet spot 20% to 60%.
Plus with charging at the destination you can leave full and arrive empty, so you don't need to replace all your charge at a supercharger as you go.
No, with the LR just one stop would be required.Same here
Thanks guys! Very helpful!
What's "cold temps" and "higher speeds"? I'm guessing higher speeds means 75-80? That's pretty much flow of traffic on the 5 freeway when going btw NorCal and SoCal. For temps, I don't think it drops much more than 30 degrees F except on really rare occasions, in which the grapevine is probably closed due to snow and is totally blocked. If it's hot, does that help or hurt range? I'm talking 100+ degrees.
But you don't have to recharge to full. You just have to arrive at your destination with 10% or so battery.Tesla says that the short range model recovers 130 miles of range in 30 minutes. So yeah, making one stop with a nearly depleted battery would be about 45 minutes of charge time.
Recovering that same range in long range model would be about 10-15 minutes faster.
