cwerdna
Seems like the free EA juice we've been seeing at some locations is more official now:
All of them were set to be complementary sessionsThe above look like ABB chargers.
One of the biggest problems is faulty credit-card readers. Not only do many of Electrify America’s stations have connectivity problems, but even when a connection is made, a charging session can be dropped halfway through. That’s because the financial session is open until a final payment amount is determined. The connection gets lost in the middle, causing the driver to start all over again. Using the Electrify America app solves the problem.
I bought one and it arrived Thursday. It doesn’t work without rather difficult modifications. They appear to just tie PP to PE with a resistor, and the car is not cool with this fakeout, at least in the newest ECU. They don’t pass through the PP pin, so I added it with a very invasive mod and got it to work.Thanks. That helped me find it again... (evhub.shop). Let me see if I can find anyone trying it.
What kind of speed do you see?I bought one and it arrived Thursday. It doesn’t work without rather difficult modifications. They appear to just tie PP to PE with a resistor, and the car is not cool with this fakeout, at least in the newest ECU. They don’t pass through the PP pin, so I added it with a very invasive mod and got it to work.
My recommendation is: Don’t buy this. If you absolutely must have ccs before the Tesla adapter ships, or your car is older, buy the setec and deal with it being 50kW.
But then you can’t use CCS.Or get the CHAdeMO adapter. It has the obvious downsides of (sometimes) being expensive, no faster than 125 Amps, and dependent on CHAdeMO chargers but it is reliable and safe.
You do you.Or get the CHAdeMO adapter. It has the obvious downsides of (sometimes) being expensive, no faster than 125 Amps, and dependent on CHAdeMO chargers but it is reliable and safe.
That's for testing it. Unfortunately I already pulled the trigger and it's in flight, but you'll save others the trouble.I bought one and it arrived Thursday. It doesn’t work without rather difficult modifications.
I have the chademo adapter, and while the adapter itself may be reliable, my experience has been that the stations are not.
Same as my setec pass through.What kind of speed do you see?
Is it possible that the battery in the adapter is dead and needs charged? (Or maybe it is too cold to provide enough power?)Hi. I wasn’t able to change using adapter this evening due the button on the adapter not lighting up and not activating the latch in the Tesla charge port to lock. Did anyone experienced this behavior before?
Until yesterday was able to charged 7 times in the last three days.
I’ll charge overnight and try again tomorrow. Sometime ago I asked here about the need to keep it charged using the USB port when the adapter has been in use regularly and the answer that was necessary.Is it possible that the battery in the adapter is dead and needs charged? (Or maybe it is too cold to provide enough power?)
