SageBrush
REJECT Fascism
Yep! ... for now.what Twiglett said about the nav and charge at arrival is spot on, it's fantastic and quite accurate!
Winter is going to be different
Nope never waited till E. Didn’t want to suck particles into the engine from the bottom of the tank lol. Was that a myth I was told?Did most of you folks drive your ICE cars til the gauge red "E" because they mostly had 1-2 gallons left or 20-80 miles depending on the type of car. I would consider "E" in a M3 to be 10% or 30 miles.
Ben Sullins (Teslanomics) took his to flat empty, 290 miles, not 310. Particularly for people in the NorthEast or northern climates, mileage drops in winter, sometimes by a healthy amount. However, the advice is, especially important for northern climates, always keep it plugged in as battery heaters will run off of AC if available rather than battery plus you can keep your car at a reasonable temperature overnight and not freeze your butt off in the morning. Sure, PUP includes heated seats. Trust me, heated seats aren't automatic warm, i.e. a 70 deg interior beats heated seats every single time. Keep your recharge level to 80%-90% as full charges aren't helpful for the battery life. So you'll always have a pretty much full charge and a predictable interior environment in the winter (or summer) mornings.What is the closest to "empty" anyone has gone and on a scale of 1 to 10 what was your anxiety level?
A gallon or two?????!! Sheeeaaat, son(daughter?). You need to get into single-digit miles remaining to make that grocery store loyalty per Gal discount really pay out.Did most of you folks drive your ICE cars til the gauge red "E" because they mostly had 1-2 gallons left or 20-80 miles depending on the type of car. I would consider "E" in a M3 to be 10% or 30 miles.
I believe Tesla's advice is do not take your car below 20 miles. so that's on a par with your comment.Did most of you folks drive your ICE cars til the gauge red "E" because they mostly had 1-2 gallons left or 20-80 miles depending on the type of car. I would consider "E" in a M3 to be 10% or 30 miles.
I think OPs question should be « what was your anxiety level? » AND « what was your wife’s anxiety level? »What is the closest to "empty" anyone has gone and on a scale of 1 to 10 what was your anxiety level?
FWIW, driving an ICE to empty is a AAA call or a walk to the nearest gas station. With an EV, it creates an instant bad day as a flat bed is involved. Deliberately running to Empty I don't believe is covered by Roadside assistance, if I correctly recall what Ben Sullins' said. Go to Teslanomics.co and look up that vid. It's very informative! In fact what he did didn't leave enough juice to safely park the car.I think OPs question should be « what was your anxiety level? » AND « what was your wife’s anxiety level? »
That was the gist of what Ben Sullins was setting out to see. Range was supposed to be 310, he found absolutely flat empty was 290, or 20 miles off max range of 310. Cold weather effects range, as does going up hills, as does extra weight in the car. The reason I didn't go with SR is in winter I doubt I'd stress-free make a daily commute to where I used to work. 220 miles/charge can easily turn into 100. I know my Prius plugin range is dramatically less in winter. Consider 20 degrees outside, 75 degrees inside and what that would do to your range. ICE uses residual heat from engine block. EV uses pure electric heat. It may well be people up north, ME, VT, MA, etc Oregon, Washington St. they may not be terribly happy with a $35000 SR version.A more interesting question would be has the range lied and ran out of charge?
It was a stormy night (okay, it was really a sunny afternoon) and I was in the middle of an unplanned emergency road trip I had never attempted before. The only time I experienced "range anxiety" was when the next supercharger was 73 miles away and my Model 3 only showed 68 miles left of charge. No altitude changes in sight. Somehow, I was able to get there with only 7 miles left by slowing down to the speed limit.
