Shoddy quality and poor QC and missing parts..
Discussion in 'Model 3' started by chinnam3, Jun 8, 2018.
  1. chinnam3
    chinnam3 Member
    Bellevue
    Yes, that is fresh air intake for Climate control. Filter I think is inside, right side of center console under glovebox. I have not checked, but I am guessing there is a drain in the lowest point of air intake for any water to drain that might enter via intake.
  2. Atari2600
    Atari2600 Active Member
    Cincinnati
    If this is now the worst (and all the previous issues have been fixed) I can't wait. My current ICE car had horrible firmware issues with both the transmission and engine where the manufacturer could not get it right until about 4 code releases. Firmware also killed my battery within the first year as well. My car is in the shop at this moment due to a known engineering issue that requires the AC clutch assembly to be replaced - it no longer works over 85F. A couple cars before that I had one where I opened the door the first week and one of bolts holding the door hinge to the car FELL OUT and the rest were loose. Temp sensor also failed. It was also the first year they started using a DSG transmission and I was lucking enough to be one of the people on the bad end of that early technology. I can deal with missing clips.
    Knowing my luck I'll probably have dead battery, cracked window, failed drive unit AND missing clips. :)
  3. buttershrimp
    buttershrimp Click my signature to Go Mad Max Mode
    ATX
    Oh my god! Outrageous! I’ve been saying it for years and no one listens .... Elon, no clip, Musk and his playboy lifestyle tweeting and snaptexting needs to learn that clip management is a real problem. Tesla is doomed. I just went out to my model s and although all the clips are there, I know that they were like forgotten and replaced during routine service. I’m installing a Blackvue in the trunk and wheel well & I’m going to remove the clips and bring it in to service and catch them red handed replacing the clip. When they try to charge me for it, it will confirm what this thread so accurately describes - a massive clip coverup.
    • Funny x 7
  4. N5329K
    N5329K Active Member
    Cheer up. It doesn't rain that often in California.
    Robin
  5. JeffK
    JeffK Well-Known Member
    Indianapolis
    Here's one data point, every car I've ever owned has been missing clips or has screws in a set of holes on one side of the car in a different set of holes on the other side of the car for no apparent reason.
  6. Dana1
    Dana1 Supporting Member
    Houston
    Sample size neglect is the statistical term. It refers to drawing conclusions on too small a sample size. If you check 500 cars and 250 are missing the clip that is likely to be statistically significant. If you checked a 100 clips on your car and 20 were missing that is likely to be statistically significant. Checking five clips and three are missing is too small a sample. None of that minimizes your concerns or that the clips should be there, just answering your question.
  7. chinnam3
    chinnam3 Member
    Bellevue
    I guess its a VW! ;)
  8. gjgerhard
    gjgerhard New Member
    Seattle
    My Model 3 was delivered August 6. I see that this issue of missing fasteners was started 2 months prior to my delivery. I, too, just happened to notice some missing wheel well liner fasteners, and found that I'm missing 6 of the plug-type push-in fasteners and 4 of bthe nut-type. I emailed the Seattle service center (Sodo) and the respondent said they checked three examples on hand and those were missing them, too. So it's now almost 3 months, and the same defect is still showing up. So much for correcting things at QA at the factory!
    On a more serious note, I also noted that one rear wheel had snug-tight lug nuts. "Snug" is not acceptable on lug nuts. Of course, I checked the others, and they were OK. What do you think the chances are that the factory will be alerted?
  9. juanmedina
    juanmedina Active Member
    SC
    I heard that the holes and studs are used for fixture alignment and are not part of the vehicle assembly. I called BS on the snug lug nuts... how you measured how much torque you need it to remove them?
    • Disagree x 1
  10. Cheburashka
    Cheburashka Active Member
    Los Gatos, CA
  11. juanmedina
    SC
    • Funny x 3
    • Disagree x 1
  12. super20g
    super20g Member
    United States
    Makes me want to pull off the plastic panels on my car and see how things look... I have a list of minor issues from delivery, wonder if that list would grow if I could see under some panels...
  13. artsci
    artsci Sponsor
    Timonium, Maryland
    Missing clips are a very minor problem. One can buy matching clips for a song on Amazon and replace them. I keep a box of clips handy for use all of the time. If you remove many panels (as I do frequently for my various projects) they will frequently break or go missing.
  14. chronopc
    chronopc Active Member
    I had missing clips. Tesla sent a mobile service vehicle to my house and they attached the clips in a few minutes.
  15. Darren Donovan
    Key West, FL
    Nobody should be expected to do this when buying a new car. Lol.
  16. JeffK
    Indianapolis
    What about a used car? I got a used Toyota from a dealership and it was missing the 12V battery bracket.
  17. Darren Donovan
    Key West, FL
    Some of my cars were bought used. It was on me to do a thorough inspection and bring up any issues with the seller, so that they can either reduce the price or fix those issues. I understand that for a used vehicle, the previous owner may have done some modifications to it, and may not have replaced all the parts, or the missing parts may have just fallen off from age, but we're talking cars that are nearly 10 years old or older. These Tesla vehicles are all new or relatively new, shouldn't be missing much, if anything.
  18. Linkeds2
    Linkeds2 Member
    Norcal
    This is why we have warranties. No automaker is perfect.
  19. Perry
    Perry Active Member
    San Jose, CA
    #59 Perry, Sep 25, 2018
    Picked up my Model 3 on 9/12/18 with a large array of build quality issues. QA is horrible.
    - came with a big black dirty hand mark on the upper headliner
    - annoying rattle coming from the seat belt mount right next to my left ear
    - my left rear door is mounted sunken in as if somebody pressed it in about 1/3 inch
    - came with a deep paint scratch on the right mirror
    - rear hatch is crookedly aligned with a huge gap on left side
    - charge door would not stay closed and when pushed closed is misaligned
    - dust is trapped in the paint on the rear bumper in inside the door panels
    - more paint scratches by the rocker panel
    - seals around the doors are buckled on two of the doors
    - seal on one door hanging off
    - and of course the missing grommets in the wheel well
    - lumbar support keeps deflating on its own (broken bag)
    Makes me think what else is wrong that I can't see.
    And yes some auto makers are more perfect than others. My last car was a 1999 Lexus GS 400 and I could not find one thing wrong with it. 19 year later and still no rattle noises. All my seals and alignments are spot on. Even if they fix all these issues on my Model 3 I think this car will fall apart within just a few years at least the interior which feels very cheap compared to my Lexus.
    • Informative x 2
  20. hoang51
    hoang51 Member
    NoVA
    Thanks to this thread, I also had missing clips in my left rear wheel liners. I didn't bother to check the rest since they'll most likely be missing too. Last week, I stopped by my local service center to have it remedied. I was told by the service advisor/technician that Tesla decided that these clips we're no longer needed. But they can put them on for me. Well, they did, but they ran out of clips to complete the job. So I'll have to swing by another time for them to finish.
