conman
Haha well I guess I had my hopes raised a bit too high. I finally got this update and took it through the punishing boulevard circuit I use to test its performance through a winding road and alas it's still got a long way to go before it can tackle it. The road has exceptionally clear markings so there is no reason it shouldn't be able to do it with a satisfactory algorithm. It has definitely improved its tracking when the curves are now associated with a crest or dip in the road - it breezed through them as though there were no inclines at all. However the main problem is, as others have pointed out, a resistance to tackling tight curves. The curves are clearly marked and low speed; the whole route is 50km/h. It crossed the lines on multiple occasions and I had to take over, but all of them were where the radius is very small. It also came to almost a complete standstill whilst coming up to parked car which intruded into the lane and just barely manoeuvred past it safely. Other times it was getting too close to parked cars for my liking and I interrupted it. What it did do successfully is negotiate a mini roundabout in the middle of the route - the recommended speed through it is 30km/h so I set it to that and it went through fine. Perhaps what I should do next time is manually drop the speed to all the recommended speeds through the tighter bends and perhaps it will make it then. Hopefully in the future it will read speed signs and do it automatically though.
On the other hand its performance in merging lanes is substantially improved as others have already said. Alas I also have not seen any improvement in take off at lights in stop and go - it's still glacial in response even with tracking set to 1. Note of course that the manual still stipulates it should only be used on highways blah blah but that's no fun.
