My 2020 is quieter than my 2019 so I would say yes, wind noise has improved. (July '19 & Oct. '19 production) I did find that small rubber tubing in the A-pillar/fender gap helped more than I thought it would.Are all these recent posts for older Model 3s or 2020?
I received mine early April & it has no noticeable wind noise at any speed (I did fit a door/trunk/frunk seal kit when I got it so maybe that helped).
A-pillar gaps are too small to push anything above a couple of mm into & I've deliberately listened for anything around that area or the wing mirrors. My car does have the A-pillar opening on the RH front end as mentioned at the start of this thread (foam filled by many of you) but there really is nothing to hear, even when my wife is driving fast & I'm the passenger (ie same seat as the LHD owners on here)
Has Tesla improved something or am I just lucky?
This is what I've been wanting to do since finding the YT video you linked to but I live in an apt. and don't have a car jack. I'll stick some foam into the area of the A-Pillar gap that you can see from the front of the driver/passenger doors and see if that does anything but i suspect, as you've noted, most of the improvement comes from the area below the fender accessed via the wheel well.I highly recommend everyone to attempt to do what I did and stuff foam or sponge between the fender and A pillar underneath. It is night and day at high speeds. I don't have to adjust my music drastically just to hear it anymore:
https://i.imgur.com/wn3QkfG.jpg
Here is the gaps of a 2020 Model 3 I took at the Brea showroom a few weeks ago. VIN 714xxx, build is 3/20:
Imgur
Imgur
It appears to have smaller panel gaps then mine. Maybe the same gap between the A pillar and fender too.
Here is Model Y in Pasadena, VIN 11xxx, with a bigger gap I noticed:
https://i.imgur.com/AO0lydo.jpg
Glad to get some confirmation though!
What exactly do you mean by securing the foam and where?As an example, I was able to secure all the appropriate foam on the passenger side including the wheel well and was able to get everything re organized on the driver's side EXCEPT the wheel well.
I’m not convinced that blocking the gap from the Wheel well will add benefit... Took a flashlight and shone it from the door opening to the front of the car. I can see light between the fender and the frunk, so air will still be able to seep in that way, regardless blocking it from underneath... I just crammed some extra black PE tubing in via the door opening with my fingers, hoping it will block the entrance to the A-Pillar completely.All,
I re arranged the A pillar foam seal and had time to investigate the wheel well area as well at that time. In inspecting that wheel well region, it definitely opens up to the base of the A pillar; however, I have a question regarding this....
Do you all think that the opening from the wheel well accesses a different opening to the A pillar than the one we all have been addressing at the windshield point? I ask this because if we truly seal the opening to the A Pillar at the base near the windshield, then technically, the moving air from the wheel well wouldn't make it in the A pillar. As an example, I was able to secure all the appropriate foam on the passenger side including the wheel well and was able to get everything re organized on the driver's side EXCEPT the wheel well. In re securing the foam, I noticed a dramatic improvement from may initial attempts, but did not notice a difference from passenger to drivers side...
In any case, I wanted to ask folks who know more than I do on the wheel well gap...
Hope all is well with everyone
AP
PNW,What exactly do you mean by securing the foam and where?
From reading through this thread there appears to be 3 areas to address in order to block air from coming through A-Pillar (that may be redundant):
Perhaps the other areas you've done (sans wheel well) resulted in blocking off the A-pillar sufficiently on one side but not on the other?
- Gap accessed from wheel well
- Gap accessed from front edge of driver/passenger door in fendor below A-pillar
- Gap between A-Pillar and fender near windshield
This should work too. I thought about that hole when I was shoving a piece of the wind reduction kit after i cut it and placed in between the A pillar and fender. I put the other end underneath the A pillar and fender from the door, and then put back the sponge in place to also hold it in place. It won't stay closer to the mirror and I don't want to use glue to hold it in place either so I'm curious if wind will ruin it. Getting polyethylene foam next Thurs along with new General AltiMAX RT43 tires Friday. Going to have my mechanic install new tires, open up the wheel well again, and I'll measure and cut up the foam and replace the sponge. Like I said, for me, the wheel well and under the A pillar and fender from door work so well for me. Here is my tube job:PNW,
Great post man, this definitely makes more sense than mine...I'll do my best to match
I would say I re did the OPs idea, but not only blocked this region, but shoved the Polyethylene foam UP into the A pillar instead of just plugging the 3 entry points you mentioned below. I did what the OP did in the first post picture but used a spudger to push that foam up the a pillar.
I feel that if this A pillar is sufficiently blocked (Foam is tucked about 1" up the A pillar), then we don't have to worry about the 3 entry points you mentioned...
AP
Azgood,
So my last thoughts are like others have posted - could the buffeting wind noise be from the mirrors and we "hear" it at the driver's ear?
AP
These are some types of seals I am considering for the windshield/sunroof glass seam:I am extremely happy now with the cabin noise, but cannot point to one thing, aside from maybe SOLIDLY plugging the A pillar space, which made this improvement - That said, I would like to help you all out as much as I can so, although mine is "fixed", there are still lingering questions...
1 - Can we just plug the A pillar with a foam expander or any other product which essentially "seals" the A pillar? Sort of like that foam piece found on the Y teardown
2 - Any thoughts on if the windshield wind noise can be improved?
-- Filling in the gap from windshield to sunroof glass? Would silicone, Sugru or any other substance have enough flexibility to safely put there? Would it help?
3 - Some of you all mentioned road noise - Aside from changing the suspension to MPPs, any "efficient" mods?
Hope everyone is doing well,
AP
Drager T14217 Dichtung Rubber Sealing for sale online | eBay
1.6M* 20mm T-shape Car Front Rubber Seal Strip Hollow Windproof Weatherstrip | eBay
Expansion foam inside the A-pillar is a good idea.
the T-shape car front rubber seal strip isn't a bad idea but for me I dont hear wind coming from the windshield but up the A-pillar to the window. Give it a try im curious.
I looked briefly into foam from a can but I don't want a permanent solution that cant be removed in case something needs to be cleaned or removed.
