Sorry, you’re right. I posted prematurely, and can't figure out how to edit my post. Anyways, here’s where I left off:
-My wife works from home and in-laws live with us so day time/peak use is higher than average household. She often works in the evenings, which is happens to be peak 4-9pm rates. She's in software so it's computer heavy work, which I assume is energy intensive.
-I’m currently on Tiered system. I’m considering the TOU-prime, but looking at our usage, not sure it would be beneficial given our historic peak usage.
-We purchased a MY in June, but started charging at home using a 110V towards the end of June.
Here is a breakdown of our current rate and TOU rates:
Tier 1: up to 403kWh charged at .23
Tier 2: up to 1612kWh charged at .30
Tier 3: above 1612kWh charged at .38
TOU-Prime Rates (Summer Weekday)
8am-4pm: .17
4pm-9pm: .45
9pm-8am: .17
I have access to supercharger with .21/kWh.
Here’s our historic usage:
June 2020, we used: 970 kWh. Billed: 217.43
July 2020, we used 990 kWh. Billed: 244.20
Aug 2020, we used: 1195 kWh. Billed: 299.06
June 2021, we used: 789 kWh. Billed: 214.49
July 2021, we used 1466 kWh. Billed: 416.22
Aug 2021 was looking like it would be slightly higher than July, until I stopped charging my car.
I’ve been using the mobile charger in a 110V. I was planning on getting NEMA 14-50 installed, but after looking at the numbers, am holding off until I can get some feedback.
Is there something really inefficient with the 110V that is causing the anomaly? Even then, my base rate as of now is .23, which is higher than the .21 supercharger.
Does it make more sense to just supercharge at .21/kWh and stay on my current tiered system?
Will switching the TOU-prime lower my bill significantly?
I’ll attach a screenshoot of daily use by hours on a couple random days when I was charging the Model Y. Thanks for the feedback.
