DJRas
No, you also need a cable adapter from the Tesla data port connector to the OBD scanner.Is this all you need to scan to a laptop or Android? no cables needed?
Diagnostic Port Index
I have certainly read that they employ this policy. Of course we can always say, if you dispute the figures feel free to show your own, and we can discuss.
I wonder if arbitration services or courts would be so picky.
No they can't. Audi sells the cars rated to "100%" in air quotes because it's still less than a full charge and you see that going in, no hidden decreases post-purchase. They can increase 100% to a higher number by allowing the cells to be charged to full voltage and that's fine because it is better than original, but they don't have to because like with Tesla's S40, software locked S60, software locked S75 and base model SR- Model 3 the voltage limit was rated by the EPA and sold in that state.Yes, they can. An etron owner can fully charge their battery. Set the dial to maximum, and charge.
Wouldn't these cases prove that the limits were artificial and not "normal degradation"? These owners' experiences may be valuable data points in @DJRas' lawsuit as it shows the cap was artificial and reversible. Normal degradation is not reversible.
A Tesla owner in Germany received a written explanation concerning the firmware based capacity loss and uploaded it on facebook.
It was made available to the service center by Tesla-HQ and unfortunately it has been poorly translated into german before it was handed out to him.
(IMO the last paragraph reveals that this wasn't meant to be a handout for the customer. ;-))
I tried to make a rough translation back to english (I don't have a ESL certificate)
Yes, there is a comparable increase in vMax... but only those of us with CANBUS readers can see it.My RM increased to ~4-5 miles @90%. No way to measure the vMax in my case. But I believe others with the CANBUS tools have reported no vMax increase.
I don't need to tell you but keep a log. I'm still certain that they are avoiding a dramatic 10% increase instantly to avoid the bad press that would bring and are intentionally distributing gradual increase in vmax over time. I also don't think you'll get back 4.2 based on their language and am expecting a stabilized vmax limit to 95% of actual capacity.Yes, there is a comparable increase in vMax... but only those of us with CANBUS readers can see it.
There are NO faults reported from our batteries. I have posted the report from the $253 test they did on my car.I don't think they changed the vmax remotely, they cleared a trouble/fault code from the BMS and the BMS adjusted the vmax itself as a result. I'm sure they could clear the fault/trouble codes on all the cars impacted from this issue remotely and the range would come back, at least until the BMS detected the issue again and set the code again resulting in the range being restricted again.
please share what you learn as I am supposed to hear back as well from my states Attorney General the 10 day limit is almost up.I’ll find out tomorrow at my arbitration hearing. I’m bringing data.
They have done this as well for people who heavily use SCs, not to disincentivize them, but purportedly to protect the pack. I haven't run into throttling, but I understand the throttle is to 90kW from the ~103kW I'm getting now. That peak doesn't last long anyway, so I don't think it's much of a disincentive for me at this point.
Thats not how it works. They build a custom firmware and send it to the car. Just like in the early days of firmware updates.I don't think they changed the vmax remotely, they cleared a trouble/fault code from the BMS and the BMS adjusted the vmax itself as a result. I'm sure they could clear the fault/trouble codes on all the cars impacted from this issue remotely and the range would come back, at least until the BMS detected the issue again and set the code again resulting in the range being restricted again.
I can confirm max cell voltage is being slowly increased, mine is now at 4.088V, was 4.077V before 2019.28.2, but has very very slowly been increasing, but has slowed right down. Increase has been 3%, from my original 11% loss since 2019.16.x.It seems to me that Tesla has done something to start the return of lost range. More and more people saying they got a little bit back last night. Not a lot, just a little. Thinks. How is that actually being affected? Are they having to tweak, ever so slightly, the cell voltage again, just to squeeze a couple of miles out of it. Sounds a bit sneaky if that is what they are doing. I would imagine that such reports might be viewed by an 'independent source' as evidence that Tesla actually are beginning to solve the problem. Has anyone checked if their voltage has been adjusted?
I stand corrected, the increase at 4.088V was more like 2%, as typical range at 4.078 was 161, and 164 at 4.088V, its now up to 165 (3%).Out of curiosity does anyone have a graph available showing the relationship between cell voltage and capacity (SOC?)?
Just trying to understand how a change in Vmax from 4.077 to 4.088 represents a 3% increase in capacity.
Is the minimum cell voltage limited to 3.6V?
