Imbalance causes capacity/range loss. The artificial voltage limit also causes capacity/range loss.
I couldn't find more plots like this:
(from @DJRas )
Comparison of this plot between different bricks, vehicles and different charge currents might be interesting.
I charged overnight at 5A from about 70% to 85%, continued at 40A to 95%, then lowered the charge to 5A again until the charging stopped, which took more than 5 hours. There was no real balancing taking place. Here is my battery after reaching the cutoff, about 5 minutes after disconnecting from the HPWC.
It appears balancing was occurring during use, rather than charging. The 20mV reported delta concerns me, however.
My pack is original to the car, 5 years old and 42K miles. Still have about 30K and 2.5 years on the Used warranty. Since buying the car I have lost roughly 3 kWh of the pack’s reported capacity.
I Supercharge very infrequently (575 kWh over the life of the car, about half of which was mine) and normally would charge to 80% daily, which I lowered to 75% after charging to 80% would cause the coolant pump to run after charge completion.
I don’t want to need a battery replacement out of warranty or even in-warranty as it seems replacement packs sometimes aren’t much better than the pack being replaced - a Band-Aid fix.
I’d like to know if my pack has a developing problem, and is there anything I can do to help keep it healthy?
Based on the ongoing discussion, it really appears attempting to balance during charging is futile, since the imbalance reflects physical differences in the module conditions. The goal of charging should be to put as much power into the pack as possible without introducing potential damage to the cells/modules.
a different limitation besides module differences
(or at least you can help the BMS out by keeping pack temp down)
the lower capacity modules are delivering power from their available capacity at a reduced percentage from higher capacity modules, otherwise the other modules would not "catch up". The end result should be that, as the pack reaches overall capacity exhaustion, all of the modules are close, so they run out at nearly the same time.
You may just have a regular old imbalanced pack which appear to become worse if you normally charge to less than 90%.I charged overnight at 5A from about 70% to 85%, continued at 40A to 95%, then lowered the charge to 5A again until the charging stopped, which took more than 5 hours. There was no real balancing taking place. Here is my battery after reaching the cutoff, about 5 minutes after disconnecting from the HPWC.
Knowing it is “bad” to leave the pack sit at 100% for a long time, I immediately drove about 70 to 75 miles, down to about 68%.
There is evidence based on TMC commentary and Tesla recommendations (at least in the Model 3 forum) that deep cycles allow the BMS to better estimate range. Specifically 20-90+%. As far as balancing goes, Tesla has stated to numerous people (in the Model 3 forum) that balancing only occurs over 85%. I don’t know if this applies to Model S packs.I'm interested what leads you to think that charging to at least 90% helps balance the battery? Tesla allow you to set your charge limit to a wide range of values. Mine is typically at 70%. If that means the bricks don't balance until higher SOC, then presumably the balance would just get worse and worse over time?
My battery seems to drift off to about 15mV difference when left standing and unplugged for a week or so. A slow charge from say 60% SOC to 80% and the voltage difference is back to 4mV.
On the idea of discharging to 10% and recharging, if the balance doesn't improve charging from 50% to 70%, why would it improve charging from say 40% to 60%? Or 20% to 90%? I expect the longer the time charging, the nearer to balance you'd get, but only if you are at least moving in the right direction.
If the car balances at all times, even when not on charge, then even without purposefully charging / discharging, the battery would balance itself. I know for sure that my car balances when charging and drifts off when left standing unplugged for some time.
I believe that my experience as detailed by the screenshots I posted (sorry for the size, they didn't look so big on my phone) supports @wk057's statement that balancing and charging are separate functions, as the closer to "full" I charged, the imbalance grew to 20 mV.For a moment I thought we might be done on this thread! .... and I could get on with life.
I don't know about others, but I find it difficult trying to make sure I have read long, detailed posts (mine included) correctly, and then work out what the poster is saying and if it agrees with other posts / knowledge.
Right now I feel we reached a point where a lot of info came together fairly clearly leaving a reasonable picture of a concensus.
It would be a shame to sink into a mess of noise again imo, and I think owners affected by these issues will keep tacking posts on without having followed the prior details.
Is this inevitable?
