DJRas
But, Are they in balance only because the BMS has LOWERED all the other cells to match the "out of balance" one?Owners of affected vehicles who have posted CAN bus data have shown that the battery cells are in near perfect balance.
Yes, after a charge eg within 5mV or so which is a very good balance.
Anyhow would need to see the cell group voltages when under heavy discharge/load to understand the bigger picture.
As you can see the response from Tesla there are certain conditions triggering the limits. Its unlikely to be a single cause for all affected but rather several different reasons that we should look all individually.
Edit: when looking at different fault conditions this old tesla patent may become handy in understanding the triggering conditions:
https://patentimages.storage.googleapis.com/d4/c7/2b/48b50249e2c13e/US8866444.pdf
In my opinion 33 mv at 7.9% SOC is pretty good.Is 33mv excessive?
I replied that this response is completely lacking, and that I want more infor on how and why this drop in speed happened. It is entirely unacceptable that they diminish functionality so severly through software update, and I'll continue to pursue more information.
One problem is that there's some latency in reading cell voltages - you don't read them all at once, it takes multiple CAN bus messages to get all cell voltages. You'd need to maintain continuous load/regen during the cycle to get accurate readings of the cell voltages under identical conditions.Do you have any more info on this? Eg where can I find how much cell imbalance is acceptable/normal under heavy discharge. On my P90DL I notice 0.2 V cell difference at 1500 + amps battery current. Under regen conditions cell difference shows 0.8 V. (Some cells showing reduced voltage under regen (3.2 V) vs high discharge (3.8 V) seems a little odd to me but I am learning this stuff! I thought owning a Tesla was going to lead to an easy car life!).
Thanks
James
I contacted Tesla for the 30% supercharge speed reduction.
Charging starts at 12%SoC with 115kW, but cannot hold it longer than 2 seconds. After 1m20s the charge rate is already below 100kW, at 14% only charge.
Taper is very strong, only 55kW charge rate at 50% SoC.
The estimated time indicator is off by 30%, consistent with the 30% reduced charge speeds I see all across the charge.
Adding 163km of range thus took me 28min, way too long.
Tesla's response: everything is normal, we don't see any problem. If you want more info, it'll cost you 110€+TVA for 1h of talk time with our diagnostics technician.
Mine is part number 1014114-00-D on 11/2014 S 85 and has been seriously impacted. I have 136,000 miles. A friend with M05/2014 S 85 with 210,000 same battery part number but unaffected.
He even has more Supercharging kWh than me.
Dutchmeeuw
I am sad to read you have decided to sell the car.
What, no sadness for me since I'm selling too?
That article is old (2006) but states a lot of the things we have always heard about the batteries. What was really interesting was it says that they limit the voltage of the cells to 4.15 V instead of 4.2 V to prolong the battery life. Somewhere along the way Tesla obviously decided to push it to 4.2 V and now they may be trying to recover from that move.Interesting read A Bit About Batteries
FYI, Tesla algorhythm has always changed the way that it comes up with rated range. Rated range=ideal kwh remaining/Wh/mi constant. Mine started out as 300Wh/mi, and now it's at 265 according to the BMS.^^ this. I've been mentioning this casually for over a year since I noticed that I'm unable to hit rated range at anything above ~275 Wh/mi, figured I was just losing my mind. Tesla has changed this number on us, which obviously makes degradation appear less severe than it actually is. It also keeps our range loss above the threshold that triggers a pack replacement. This is major!
Also weird that there are no threads about this at official Tesla Forums. Could Tesla be removing threads relating to this issue? Seems strange nobody over there is discussing it.
