DJRas
Ok... so i took a flight this week and parked at the airport for 4 1/2 days. When I parked I had 100 miles (46%) remaing rated range. When i returned I had 74 miles (34%) rated range. All precondition, thermal protection and everything else I can think of turned off.
I then drove 55 mikes to a Supercharger station in 55 minutes and had 4 miles (2%) rated remaining. From TM-SPY you can see my battery pretty off-balance (132mv) after 3 minutes waiting before starting SuC.
Charging to 90% at 72 kW charging station predicted 1 hour and that is about what it took.
Now the interesting bit.
While charging I was watching the displayed miles added and kWh added on the dash. The miles added exactly matched the miles added in BMS (ScanMyTesla) data.
HOWEVER, the kWh added did NOT match. The displayed kWh added was exactly miles added times 0.295 (magic number). At the end the display showed 192 miles (teslafi said 192.28) added and 57 kWh added. BUT the BMS said only 53.2 kWh were added (53.2/192.3 = 0.276 MY magic multiplier).
