AwlBidnz
Old Guy to be driven around for yrs to come
Anything Tesla can do to extend the life of the battery by reducing degradation, saves them &, hopefully us, money.
My passenger seat has this same problem. Need to get it fixed before my warranty runs out.
My iPhone 6.
Yes, of course!
Tesla has all right to define what available capacity corresponds to the 100 % mark shown to the driver.
Mine is fully charged but as you can see my battery has lost 48% of its original capacity and my cell voltage is now maxed out at 3.8V (4S)..Says 100 percent in my case
Also known as foreshadowing.They got in BIG trouble for this so it's funny that you use THAT as the example. As a result of the multiple class actions, they had to provide $30 battery replacements (essentially free by comparison to the normal price) and as part of the settlement, they had to update iOS to expose the actual battery wear level in settings.
It is obvious there are differences of opinion as to what “degradation” means and how Tesla should deal with it. I’ve been doing engineering long enough to know that very little in life is black and white especially when dealing with new technology or new uses of existing technology. You learn and adjust. In my opinion, a warranty replacement should be dependent on a loss of actual usable battery capacity. If Tesla has to limit the SoC to keep the battery operating safely and you fall below the warranty limit as a result, you should get a new battery. It doesn’t matter what causes the degradation, natural or Tesla imposed for safety/longevity. Again, that is the opinion of some of us here, and there are plenty on this forum that think otherwise.What do you agree with? egn1 is 100% wrong, if the battery is unsafe, for any reason, Tesla should call the owner in and change the battery under warranty. End of story.
Just limiting the battery at their own discretion is a slippery slope with no end.
It is not written anywhere that your 8 years limited warranty on the battery will void if you have a certain charging pattern. So Tesla should just own up to the problem, learn from the experience and change the batteries affected.
That we can agree 100% on. I would just say theories though, since all theories, for or against, is unproven so far.Tesla definitely needs to articulate what is going on. Their current lack of candor is feeding conspiracy theories.
Following my previous post regarding the disappointing response from Tesla's "battery management team" I just received this note from Tesla's "support":
"Thank you for reaching out to Tesla. I am sorry for the delay in responding to your email.
We are aware that a very small percentage of owners who own older Model S and Model X vehicles may notice a small reduction in range when charging to a maximum state of charge. This occurred following a software update that we released last month to protect the battery and improve battery longevity of Model S and X cars, and does not have any other impact on the vehicle. While charging behavior will always vary based on how a vehicle is driven, charged, vehicle age, and other factors, we are working to improve the impact on range for this small group of owners."
So we are seeing some progress here.
As compared to the previous responses from Tesla that there is nothing wrong with my battery, with this recent correspondence Tesla is finally acknowledging that some owners have experienced a range reduction as a result of last month's software update; and they are working on a fix. I let my local Tesla service manager know that I appreciated his escalating this to a department that would responsibly respond, and that for now I will be holding off on filing an NCDS claim in anticipation of the fix arriving in a timely manner.
I did reply to the support team that while this range reduction may not have a noticeable impact on local commute driving, a 30-mile loss on road trips is significant and not viewed by the affected Tesla owners as "a small reduction in range". I will continue to post any correspondence received from Tesla on this issue.
I'm skeptical about a software fix for range return. If I understand it correctly, the Li-Plating is not reversible by a significant amount. @IngTH , @egn1 and @wk057 comments on the viability of a software fix to safely reclaim the range loss would be appreciated.
If these batteries were not safe and that forced Tesla to cap the capacity in order to avoid further hazard I definitely do not want to take back the range loss and live with a unsafe battery just because of the public pressure. If the batteries are unsafe with the pre-update range they need to be replaced under warranty.
P.S. There has to be a clear distinction between a battery pack that has safely degraded (normal) and the one which is in an unsafe state (abnormal).
I think you may misunderstand how the drop in range has happened.
Welcome to the club!Just curious, has anyone experienced a range reduction with the recent software update.
My full charge capacity dropped from 268 down to 228.
I purchased a 2015 Model S 85D with a ‘suggested’ range of 270miles.
Back in 2015-16 I did a lot of long trips down the coast from SF to LA and managed full charging to 268,
When doing regular driving/charging I would do the recommended daily charging,
After the recent update my full charge range DROPPED TO 228. With the 80% charging now being imposed by Tesla at supercharger locations my range is now 200.
I purchased a Model S 85D for the range and now Tesla has reduced my 85 to a 60.
Worse then that they state that this is NORMAL BATTERY DEGRADATION and not covered under the warranty.
MAD AS HELL.
FreddyQ
OK I was trying to help. I have also read ALL the posts. I took the time, and effort, to explain it in detail as your comment about being nervous about recouping the lost range because you said you were sceptical about a software fix to get the range back, and that you wondered if Tesla had capped the batteries because they were not safe. I thought they were unusual statements to make given the situation. Both are views which I do not share. But I can tell you are very knowledgable about the whole issue. I will have misunderstood your intent. Of all the contributors on here, you are in the top half dozen that the rest of us should listen to. I should take more note of authors!Thanks for sharing your thoughts.
Clarification: No misunderstanding here at all. ....
Specifically, what part of my message gives you the impression I do not understand why the drop in range has happened?
Cheers!
That limit is easily overridden.J With the 80% charging now being imposed by Tesla at supercharger locations my range is now 200.
Droschke I can understand your nervousness, but I think you may misunderstand how the drop in range has happened. It is purely down to a software change. Reversing that change should be very easy, and very safe.
First thing. The range has NOT disappeared because Tesla have discovered a new way of calculating degradation. Tesla are working on, I think, identifying the amount of Li Plating in a cell. (It’s not the same but think of oxidisation on metal). The battery pack is made up of hundreds of individual cells. Each cell has a nominal value (3.66V) a maximum value (4.2V) and a minimum value. When the cell gets to maximum value, the car says it is 100% full. When it gets to minimum value it says it is 0% or empty. What Tesla appear to have done is change the value when the car thinks a cell is full. I understand the new value is about 4.1V, or thereabouts. (It may be different per car). So now, when your cells get to 4.1V, it says it is 100% full and stops charging. But it is full of cells at 4.1V, not 4.2V. So the overall battery charge is less, so Range is less. It is NOT the case that Tesla have discovered lots of cells with Li Plating and that they are actually more degraded than we thought. They just, artificially, hold less when full.
The safety aspect is really in the future. Li Plating creates the conditions for Dendrite growth (spiky growths inside the battery). If the Dendrites grow too long, they can contact the other Diode, causing a short circuit, and normally a fire. So Tesla appear to be trying to identify Li Plating early, in order to stop, or reduce, Dendrite growth. Good thing to do. Changing your battery capacity back to what it was changes nothing, absolutely nothing, in your battery in regard to current Li Plating or Dendrite growth. If you had it before, you have it now, whether you are at 4.1V or 4.2V. So it may be a safety issue some time in the future, but it’s not one at the moment.
A long post but if you understand how it works it will cause (hopefully) less worry.
