I do have one at home but I'm afraid to go in a trip because it could take 3 hours to charge from empty to full. That means I either need all kinds of time, which I don't, or I use another car, which is what I've been doing
I definitely see regen limits on a 40F battery, so you can't expect it to charge at full speed until it is warmer than that.A 40-50 F battery is not the cause of getting a 25 kW or even 35 kW charge rate at a supercharger.
The person reported 27 kW charge rate after driving 35 miles in northern California where it is 50 to 60 F right now. Worst case the battery was 55, probably higher. Temperatures definitely wasn't the cause to get such a low charge rate.
It varies from solid all the way to about 1/3 of the way dashed when starting, and I get the message the brake Regen is limited but rarely have I noticed that during any of my charging woes.
Not yet. Work is very consuming this week. Unfortunately it will be next week before I'm able to test everyone's ideas, I've only drive 8 miles this week, I don't think I'll be able to get to 120 Miles in a single trip though-that does sound unreasonable to get sufficient charge rates, unless if course Tesla is trying to discourage using SCs for only road trips? I have she'd other M3 owners charging at the same time and they were all getting significantly higher rates. Again, I'll report back next week. Thank you again for the insight!!The Model 3 is much more conservative with charging speed when the battery pack is cold. It’s certainly possible.
@Racerrich have you taken it on a longer trip yet? Let us know how that goes.
Battery at 115 of 310 miles. Outside temp at 54. Initial charge rate 79kw at 321mph. The highest, by far, that I've ever seen it! It dropped off fairly quickly to 59kw at 240 mph at 173 miles and keeps dropping. 54kw at 219 mph at 186 miles. 49kw at 199 mph at 200. 44kw at 179 mph at 232. 35kw at 144 mph at 250. 26kw at 105 at 268. Not what is advertised but certainly way, way better than I've ever seen.
I thought the same thing at first, but if he was at 115 miles of range remaining, thats 37% remaining (out of 310), so that's probably not it.You're charging too soon. The high charge rates are only from about 10% to 60%. After 60% they taper off quickly.
Overnight temp is an interesting datapoint, as RTPEV suggests
Wow! Very good! The Model 3 LR is going to be a road tripping machine!
What was the displayed Mi/hr charge rate?
I believe the fastest superchargers can output 145kW max...but it doesn't look like any Tesla built so far can accept that kind of charge rate.
What software version is your car running?The Hawthorne, CA V3 SuperChargers went live today! Plugged in and the display showed me 250KW for a short time and finished up about 15 minutes later still going at 183KW. Not a full charge for me... about 75 - 80%.
View attachment 396868View attachment 396869
Wow! Charged this morning and saw 463 mph!!!! Incredible!!!Good news. 120 miles is not needed to warm the batteries, at least in CA. I have no idea what changed. Maybe Tesla really did something when they had my car, even though they said there was nothing wrong? I've charged twice since. Both at the same stall at the same sc and both times were great. The highest rates that I ever have seen. 299mph. Wow! I'm very happy! Could have been bad superchargers, Tesla did something to improve my car, I let the battery drain a little lower than normal both times, I don't know but I'm happy! Thank you again for all of the input.
