The pack cannot be charged quicker than the individual cell. If you put too much power in to the cell at any given time it will burn out.
It doesn't matter how much voltage, current or active cooling you have available, you cannot charge the tesla cells much faster than about 1C (on average, ignoring charger curve) (right now you can charge over 1C when the battery is in a low SOC, but that drops to < 1C as it fills up)
In order to charge a battery quicker you need to change the chemistry.
All the cells in the car are already charging simultaneously. Using a higher voltage merely means that you put more batteries in series, it's not like you're applying a higher voltage to each cell (which would be dangerous unless the chemistry supports it).
Wouldn't it be great if the Model 3 shipped with an 800+ volt battery that could charge at 240 kW or higher? Here's hoping...
Hopefully so... that would be in the neighborhood of 2.5x the power accepted by current packs... so quite a jump...Elon said V3 would be more than 350KW. I assume he is taking about that much going into a battery. It's possible it will be split like today's A and B supercharger. Based on my assumption, I think Tesla will create a Pack with the appropriate C-rating to accept the charge.
Here is my guess:
For current cells, they are very close to the C-rate limit. (tho I can't find any reference about actual limit)
120kW / 480V = 250A
250A / 74 = 3.4A (74 groups in parallel)
3.4A for each 3100mAh cell is ~1.1C.
The reasonable way to apply >350kW is:
1. increase the cooling ability on the car
2. raise the voltage of SC from 480V to 1000+V
Thanks for correction!Current peak voltage of the packs is~400V, not 480. Several models of the cars accept <1.5C for some portion of the charge curve.
I am not sure about the max 333A. Maybe the regular 85KWh battery is different. But on my tesla the fastest charge rate for me was when the car is about 385V or so. Attached is the specs on the supercharger V2.0 themselves.Look again. The maximum charging speed in kW is achieved at low SOC when the battery pack voltage is low. On the big battery packs (85/90/100) the low SOC voltage is around 355 VDC. The peak SuperCharger current is actually about 333 Amps. That is how you get the maximum SuperCharger power for current vehicles.
355 V * 333 A = 118kW
Before I posted, I checked Bjorn's videos just to be sure. Just look at the first 30 seconds of the video below.I
The max I have ever seen on my car is 290A.
Not sure why you guys need to calculate the amps for each cell. ...
You get C by just looking at the energy capacity and power charge rate.
True... within the bounds of today's battery technology constraints.If Tesla wanted the Model 3 to accept 350 kW of current, it can design the battery pack to do so, including chemistry or whatever else is needed. Nobody really knows what is going into the Model 3 pack. One of the reasons Tesla built the battery gigafactory was so it can manufacture what it wants and not be dependent on someone else.
Too bad the existing superchargers cannot be upgraded to 350kw. Infrastructure in place at each SC wont support it, so new supercharger sites will be required.
Just noticed a new Electrek article about Supercharger v3 - not a lot of definite info, a bit of speculation about ZEV credits.
Tesla’s upcoming ‘Supercharger V3’ is the last piece of the EV adoption puzzle – and means more ZEV credits
[Edit: And insideevs.com - Elon Musk: Tesla Supercharger V3 Coming With Output Over 350 kW ]
