All you fanboys can criticize me all you want. The fact is I had my car in for service two weeks before the ball joint failed because of excessive tire wear. The service center aligned the front and read end. At that point the excessive ball joint wear should of been detected and all this would be mute. It was only after the ball joint came apart that I realized I had a problem. If it happened at a high rate of speed it could of been tragic for myself or others.
Well at least you had a symptom of the problem nailed down. Was the vehicle making creaking noises too? What did you specifically ask them to do? Did you ask them for an alignment? There should have been more symptoms.
My criticism of you is very narrow... exaggerating the communications you received from NHTSA and being a willing patsy for anti-Tesla trolls to the point of promoting their lunacy. You are right to report the issue to NHTSA, but without Mr. Wivaneff's idiotic embellishment. Certainly, if the Service Center caught the problem, which I would have expected that they would, the air shock and other parts might not have failed. What was their response to not catching the problem at that time?
