(Hang in there this will be a long post)
On another forum I hang around discussing electricity grids with a mixture of people, including power engineers.
That experience is similar to TMC, hang around knowable people you pickup jargon and learn things.
One of these people is an ex-power-engineer who is conservative and doesn't like change.
The criticism of RE that he regularly makes is the following:-
- It doesn't add to system strength.
- It doesn't have inertia
- It is not dispatchable...
In all of these cases batteries are the answer, and this is the point of my post.
Batteries are going to do most of the work in grid control and system strength in future.
This article is relevant, I recommend you read it after reading my post.
Control versus inertia: Lessons from South Australia's latest separation | RenewEconomy
The traditional FF grid was built before computers and the internet.. my simplified view is as follows:-
{non buffered} Synchronous Spinning machines with Inertia - control mechanism - Frequency and voltage {+internet recently}
After future grid with high RE looks as follows
{buffered} independent generators - control mechanism, computers + internet.
The aim for an electricity grid is :- stable frequency and voltage i.e. Supply = Demand
A traditional FF grid is real time non-buffered, changes in frequency (demand) essentially cause plant to ramp up or down changing supply.
Those with a pro-FF agenda or mindset say this control mechanism is the best solution and overlook it's limitations.
Rather than perfect control this solution delivers voltage and frequency that is mostly within spec and does vary in quality by location.
As can be seen in the link I posted the Hornsdale battery performed very well in the separation event... in terms of keeping frequency and voltage stable batteries have one big advantage, they can smooth out supply and demand and do that quickly.
So if we take the criticisms above:-
- System strength - most inverters automatically back off (over supply), batteries help (under supply)
- inertia - interia is simply a form of stored energy - batteries can store a lot of energy.
- Dispatchable - provided they have stored energy, batteries are dispatchable.
The main advantage I see for batteries are:-
- Domestic - time shifting, islanding, system strength
- Grid - time shifting, system strength, "Emulating Synchronous Machines"
"Emulating Synchronous Machines" - is my concept derives from discussing the SA separation event.
Essentially:-
Battery + Computer (looks like Synchronous Condensor) << Frequency and Voltage >> Happy FF machines*
Happy FF machines* = It is OK guys he is one of us...
Why this is relevant is a Battery + Computer may be cheaper and work better than Synchronous Condensor.
More generally my opinion is the combination of batteries and inverters can work together to control frequency and voltage in a much tighter band than a traditional FF grid.
It might not play out exactly as I predict but the future is bright for batteries at domestic and grid level, they are the logical way to ensure stable frequency and voltage.
