kpeters000
Any of you later year MCU1 owners ever successful in getting Tesla to do a MCU2 upgrade (for the cost difference) when your MCU1 failed under warranty?
Frank, just checking, why did you say does Netflix when you have a WIFI connection, based on your car year, you should be grandfathered with Unlimited Premium Connectivity. Netflix should work on LTE as well
Yes, sentry mode recording works great. I captured a semi nearly wiping out yesterday.
Anyway, I have an issue with the dashcam - how do you tell it to run continuously? I have Sentry mode on, and I have a USB stick in the first USB port with a folder called TeslaCam. The stick is FAT32 formatted. But after 1/2 dozen drives totaling over 60 miles, I only have one, very short video capture of me 'driving'. It does work for 'capture on honk' and I do have some Sentry-activated videos that I forced to happen. But I'll be damned to find how to tell it to always record when out and about.
It does always record while you are driving, but it only keeps the last clock hour of recordings, plus any 10-minute clips you save by honking the horn or tapping the dashcam icon on the MCU. (So if you drive for an hour, and park for 45 minutes there would be the last 15 minutes of driving still on the drive.)
Am I supposed to doing something with the icons on the top of the screen prior to driving or while driving?
Consider keeping them both. Belt and suspenders. In case one doesn't work (full or failed USB drive or sometime). Also maybe different resolutions or have different quality depending on the light (day, dusk, etc).Can you either tell me or point me to another post (I did do a search) that talks about using this feature? Once I know it works, I can get rid of my front-window-attached external dashcam. Thanks!
Same for me, I will still keep my front-window-attached external dashcam for the same reasons. Last week, on the highway, I was passing a car driving on the middle lane, when this car suddenly moved into my lane without any notification. I was on NOA and the car initiated an emergency brake and I pressed the brakes at the same time to avoid the accident. The Tesla dashcam recorded 2 videos at this time, but the incident was not on the videos (it's was just in between !) But my front-window-attached external dashcam recorded the incident.Consider keeping them both. Belt and suspenders. In case one doesn't work (full or failed USB drive or sometime). Also maybe different resolutions or have different quality depending on the light (day, dusk, etc).
Is this any different than regular Homelink? For example, are they able to determine the open/close state of the door rather than be a "dumb" toggle?I can use the MyQ garage door openers with my Tesla now.
The smart thing to do is not to send a signal to do anything if the door is already open.
I can't see the garage door until I'm in front of it.Just hit the skip button that pops up and it won't open or close but you've gotta be 150ft away before it gives you that option.
I guess you'll need to get a blue check and tweet Elon for smart garage feature that also looks at the garage door state.
I hate how you are limited to the exact speed limit when using Traffic Light/Sign control ESPECIALLY when they have the wrong speed limit for the area!
Describe all the steps and testing you did. 'reboot' infotainment? Test on wifi? What apps were tested in theater? All have issues? etc.Had my 17S done last week. Its really laggy when in theater. Anyone else or is that normal?
Your speed limit prediction has a lot of company on this board but if it happens it will kill sales of self-driving systems for urban drivers. Driving the speed limit on metro Phoenix streets will get you constant tailgates and cause road rage. Same deal in most cities, I suspect.This may be a preview of how FSD will work in the future. It's likely FSD systems will be required to follow all traffic laws, which will mean coming to a full and complete stop at stop signs and not exceeding the posted speed limit - manufacturers may be held responsible if the FSD systems are programmed to disobey the law.
However... When systems are operating in "driver assist" mode, where the driver has the responsibility for driving, Tesla should allow the speed limit to be exceeded. It's reasonable to set the initial speed at the speed limit, and then allow the driver to increase the speed setting, taking responsibility for breaking the law.
If FSD systems always drive at the posted speed, that's clearly going to create challenges on roads shared with non-FSD vehicles driving at higher speeds. Though because FSD vehicles should be safer to operate at higher speeds, it's also possible we could eventually see higher speed limits for FSD vehicles, once the technology has been proven.
