1. I’ve moved a number of weather-related posts into here.
2. Winter driving conditions - slush and wind, for example - affect the fuel consumption, which is range, just as much for a truck driven by diesel or mule train as it does an EV. Until you get down into Arctic conditions, cabin heat is the only situation where a diesel rig, with all that waste energy having been converted to heat, easily can be repurposed, thus giving it the advantage over EV. The ameliorating factor here is in torrid situations, where it is the opposite: while both have to run the same reverse heat pumps, the diesel rig also has to combat the nascent engine heat, which seeps into the cab regardless of insulation.
3. In Arctic conditions, the picture is unclear. An EV needs to maintain pack temperature at a certain level - this we know. But a diesel rig also must idle 100% of the time, both to keep its diesel, crankcase oil and transmission fluid from turning to honey or worse, and to provide the cab with the necessary heat that only the engine can provide.
