Soo.. do you have a source for that, or have you observed them first hand?
This is essentially what I was suggesting in my last post.
Say you have 1MWh in the physical battery, but it is dynamically "unlocked" only to allow 500 physical miles. Perhaps in ideal conditions only 1.2 kWh/mile is needed. That is only 60% of the pack is needed. So the software knows to keep the SOC within 20% to 80%. The driver only sees and has access to the middle 60%. But suppose that under extreme conditions (weather and grade), 1.8 kWh/mile is needed. This unlock the middle 90% of the battery and the software holds SOC between 5% and 95%.
In all cases, the driver is limited to 500 physical miles but the fraction of the battery dynamically unlocked varies from about 60% to 90% of original 1MWh capacity. This could be why Tesla spoke of a 2kWh/mile upper bound. This may be sufficient for 99% of all driving conditions, but Tesla will want fairly strong control over depth of cycling to minimize abuse to the battery. Tesla can't put a 1 million mile warranty out there and allow drivers to abuse packs. They've got a software layer between the driver and the pack.
Ah, I didn't have the context of a factory visit... thanks.He likely saw them late in the evening at the end of September while visiting the factory. (And isn't allowed to admit it) (Referenced in post #1818)
I have a vague recollection of that, but it would be good to locate specific language used. Often there is enough ambiguity in what Elon says that you can't fully nail this down. We know on the price side the Semi is not merely equivalent to 1MWh of Powerpacks, so what else is different?Forgive me if it's this thread already... but I remember seeing discussion that the Semi battery chemistry may be similar to the PowerWall/Pack chemistry for cycle-life reasons. Was this stated by Elon... or was that just conjecture?
This article I linked upthread explicitly says the Semi will use NMC chemistry, though IRRC the author doesn't reference a source.Other brain blip:
I believe I recall J.B. mentioning recently that due to the high energy figure, the power requirement was not a limiting factor. That might lend itself to the TE chemistry.
Musk stated the battery pack uses the same cells as the Powerpack, which us NMC chemistry. Each Powerpack is 3,575 lbs and has 210 kWh of energy capacity.
Ahhh thanks... that's where I remember seeing it:This article I linked upthread explicitly says the Semi will use NMC chemistry, though IRRC the author doesn't reference a source.
That was my thought too about the mounting hardware.second pic, looks like it has a camera down-and-back and also straight down, though that might be mounting hardware
third pic, I don't see a camera, looks like mounting hardware
Yes. And my thought is the two circles above it are proximity sensors when backing up to a trailer. If those are proximity sensors then the ones on the sides are also possibly proximity sensors for the moveable flaps controlling the air gap to the trailer. Hard to tell 100%. Those could just be part of the mounting hardware as mentioned above.having a camera above the hitch would make perfect sense.
They can send stamped parts back on empty battery trucks for the semi.I think they will build the semi in Sparks with some parts made in Fremont, so there will be no deadhead.
