I was in Romania last fall. Everyone I talked to had heard of Tesla even though I didn’t see one.
Makes sense, even I have heard of Dracula
Supercharger V3 could be interesting news since Tesla had indicated they had a way to lower deployment costs. "Fueling" infrastructure is the only big hole in Tesla's plan so far and this may fill that gap. They could easily double the size of their current deployment along highways in the US to reduce range anxiety.
But what is the reason for Model Y reveal, at all ? I actually don't see any strong reason for revealing it more than 2 months before delivery.
- Fear of details leaking
- Deposits
- Boost SP
Closer to BMW 4 series than 5 in terms of vehicle sizeNot really, I have not measured, but judging from some dimension drawings I got, Model 3 and BMW 5 have roughly the same distance from steering wheel to rear seat back. Translates to probably about the same interior space, which would be noticeably larger than BMW 3 series.
Also BMW 3 series doesn’t have double wishbone front suspension which both Model 3 and 5 series have.
In my opinion, Model 3 is comparable to BMW 5 series and Benz E series. Which is probably why Elon wants to name it Model E in the beginning(before being shot down by Ford who owns the trademark)
Btw, any 5 and 3 series owner here mind to massure that distance?
Model 3 measures from 61 to 63.5 inch depending on steering wheel position adjustment.
(I measured from the top of the steering wheel to the seat back of the rear, around shoulder height)
Q. So 200 to start and maybe 250 with liquid cables ?
- A. No, I was told just a flat 200. That said, 200 at 400v is faster than the Taycans 350 at 800v"
The reveal determines demand which determines ramp which determines the number of production lines required which determines the production equipment order which has a lead time to manufacture, deliver and install. You can't squeeze all of that lead time into 2 months. Not to mention the other things they need to plan for based on the demand such as the number/size of Supercharger and Service Center locations.But what is the reason for Model Y reveal, at all ? I actually don't see any strong reason for revealing it more than 2 months before delivery.
- Deposits
- Boost SP
Some interesting Supercharger V3 comments on reddit. No idea if its accurate but seems mostly plausible. 20% to 80% charge in 13-15 minutes for Model 3 would be an extremely significant development in my opinion.
Apparently they were told by a friend who works at Tesla.
Source: u/NetBrown
- "200kW is correct.
- All Model 3 battery chemistry will be able to handle this.
- Total redesign from the current v2, which uses repurposed vehicle chargers. V3 is done from start using industrial inverters based from Power Packs.
- Ideally meant for long distance only, will be deployed in far out places to bridge gaps (Forks,WA will be one of the first places in the NW completed).
- Initially will not have liquid cooled cables in early release, but all v3 will eventually have liquid cables."
Q. Source?
- A: You won't like it, but a friend who works there. We will all see if I (or rather he/she) was lying to me in a couple of days.
- Also: Cars which can not use full rate will still be able to SC at these, just will take longer.
- Suspicion of mine: firmware update in late march will enable not just the 5%power increase but also have v3 support in it
Q. What would be the equivalent in mi/hr roughly?
Q. How would it possibly cut the time in half?
- A: At full power? Not sure, but supposedly the taper will be different too. Target charge time is to cut the prime 20-80 zone in half in terms of time
- Well half the timeframe for this on a 3 (which supports the full 200kW speed) would still be about 13-15 min. Definitely faster, but not quite a gas fill up yet.
- A. Partly by increasing power, partly by adjusting the charging curve.
- Not all chemistry can handle it, and SC v2 was put out before several changes in chemistry were made. This upgrade should allow newer cars to do a more aggressive charging curve without cell degradation.
My reply was in response to what the Model 3 compares to, not speculating on the size of the Y.I expect Nissan Rogue sized. It is/was (haven't checked lately) the best selling vehicle behind the full size pickups and I can vouch for it being right sized for the class.
Unless:Well from that we know they don't understand Power...
'We're here, we're staying here, and we have a bright future (even though we just announced we're closing our stores and cutting our prices) so go to your computer and order that Model 3 you know you want (even though some unhelpful person is telling you there won't be anyplace to get the car repaired and the warranty will be useless when Tesla goes under).'
Source: u/NetBrown
Q. Source?
- Deposits
- Boost SP
- Any extra power (assuming the extra 50kW the cabinets can produce versus what the chargers are delivering if the cabinet is maxed, or if only partially maxed, any extra power) can be shared across cabinets.
I'm assuming the vehicle Tesla have in their sights the most, if there is such a thing, would be the Porsche Macan.Closer to BMW 4 series than 5 in terms of vehicle size
I guess the only point the shorts are going to have now is there will be no more vehicles for Tesla to announce after this year. If Elon can't get the fan boys to hype/buy the stock up after a reveal every now and then Tesla is surely going to go bankwupt.
and here comes the Tesla minivan.... LOL
People who are on the bankruptcy train are not going to come off that easily. Anything and everything can be called a fraud/lie. Ofcourse, the fence sitter / casual observer can possibly be swayed and that matters.This is a very good point. I was wondering myself. Squashes the bankruptcy rumors. Same thing with Supercharger V3 and Maxwell acquisition. Would they be doing all this if things were dire?
