acoste
JFYI, the Tesla Semi has similar weight to comparable Class 8 trucks, which is ~17,000 lbs plus 200-300 gallon of fuel which is another 1,400-2,100 lbs of weight: a modern tractor trailer can easily weigh ~20,000 lbs.
Diesel engines, the steel chassis to distribute all that force plus fuel weighs a lot.
That the Tesla Semi is going to weigh too much has been a TSLAQ lie from day 1.
Do you have some numbers to support this? I'm just guessing here on the electric parts and some other numbers:
diesel engine 3000 lbs
transmission 700 lbs
300gall fuel 2000 lbs
- electric motor + inverter -1500lbs
that is 4200 lbs for the battery
current battery is at ~243Wh/kg
4200 lbs = 1900kg
243*1900/1000 = 462 kWh battery capacity doesn't seem enough for a semi trailer.
Diesel truck:
average 18-wheeler gets 5.9 mpg,
300 gallon x 5.9 = 1770 miles
Electric truck
Model S 100D would get 40-42mpg on diesel at those speeds (~7 times less consumption than truck). Range might reach 350 miles on a 100kWh battery.
That is 350 miles * 462kWh / 100kWh / 7 = 231 miles
