Looks like anything in a decent offset is going to be pretty spendy. I guess 19x 10.5 will be it for now. And before anyone questions it, yes, all the normal wide wheel/tire supporting mods are included.In the next week or so I'll be picking up a set of wheels. Looking at 19x11. Curious as to what would be the best offset for them? I'm eventually going 305+, so I'd like to go wider than 10.5 to start.
I'm not adverse to 18", I thought 19s had the beter selection of wider track/autox tires.Dan, why 19"? 18x10.5's fit and generally have a better tire selection.
Like the fitment. What wheels?Very happy new '23 M3P owner here
Any concerns with 19x10 +40 fronts with 275/35 PS4S and 19x11 +55 305/30 PS4S? Stock everything.
Looks like plenty of clearance in the rear and tires are well under the fender. Fronts will need 3-5mm spacers, and stick out a little. This will be my track setup (long track, no autocross or hill climbs)
I've read most of this thread, but there's a LOT to digest.
What areas should I be checking for rubbing?
Will I have issues with the outside of the tire? (read the post about cutting the outside of the tire auto-crossing)
Will I have issues at full compression?
And can I run 5mm spacers with stock studs (I'm not sure what 'giving up precious knuckle clearance' means)
I understand this wont be the fastest setup, but I already have these wheels/tires from my previous car.
Clearance (with janky 5/16" spacers)
Front (top down view)
Rear: (top down view)
Front fender, inner upright. Maybe inner linkages in the rear. I'm not aware of people running a +55 offset in the rear, that's pretty deep. While there is plenty of space, the is a limit somewhere. So, maybe take the spring off and run the wheel through its potential travel to check.What areas should I be checking for rubbing?
Yes, potentially it can rub. You setup will be marginally closer to the fender than the linked 265/35-19 setup on 19x9 +30 wheel. (You're on +35 effective offset + 5mm wider tire, +mounted on a wider rim).Will I have issues with the outside of the tire? (read the post about cutting the outside of the tire auto-crossing)
See above.Will I have issues at full compression?
Possibly, but a lot depends on a particular rim's lug seat thickness. Count the turns required to tighten with your 5/16" spacer (8ish mm) and add two. If that number is over 7.5, you should be safe-ish.And can I run 5mm spacers with stock studs (I'm not sure what 'giving up precious knuckle clearance' means)
Looks good. Drop it with some springs and it will be on point!
Is there problem in the rear or in front? or both?Regrettably, the Goodyear Supercar 3R in a 305...is not a 305. They measure 330mm wide.
The Falken RT660 in a 305 measures...305mm.
The Kumho V730's in a 275 measure 280mm.
Unfortunately, I can't see any way of fitting an entire inch more of tread on this car. Oh, and they shipped me tires with 3-year old DOT's again - so there's that. At the very least, I can provide a nice visual representation of just how massive they are.
MasterC17 isn't your average Tesla owner...Wait, how many of us have a stack of 8 tires in our garage?
(295 hoosiers on bottom, 275 A052's on top)
8 in the garage?Wait, how many of us have a stack of 8 tires in our garage?
Sasha would be very sad if a car competing in the challenge series had UPP parts on it.Is there problem in the rear or in front? or both?
I know UPP sells wider fenders for the front that might help you.
I actually have 24 in the garage, I just only have 8 of them stacked to the roof. (look carefully, a stack of 4 by the garage door, 4 more on the wall, 4 more on the car, 4 more somewhere else...)Pffft 8 in the office and 4 in the shop is the hip way to do it.
