bnsfengineer
I just found out I don't either, delivered 9-16-17Im pretty sure that all car's produced after July 1st have the "Three Position Dynamic Turning Light's".
No just found out that I don't haveHave you taken this issue up with your SC?
Noooo.. I totally forgot I had my lights done as well with Xpel!!!Update.
I GOT THE ADAPTIVE LIGHTS INSTALLED TODAY!!! This was unexpected as I took the car in to fix an issue with the driver side door panel and diagnose the computer systems to see why OAT updates were failing about 50% of the time. They just happen to have the lights got those installed.
I'm still waiting for the engineering team to change the options on my car in their system to have the adaptive lights, then I can get an update to enable the feature. Otherwise, the install seems to have been done well. No noticeable damage to the fenders, hood, or bumper. And the PPF looks ok as well. I just need to get the headlight film reinstalled.
My Model S 75D built date is Oct 2017 and took delivery in beginning of November without PUP. It has the adaptive lights installed and was tested in my driveway. Also has the option to disable/enable the function.
Lucky
Well that makes me feel a little better! Sent them an email "No Response"Mine was build have october. Didn't get them
I had my lights installed today (thanks Iris for helping move this along!), and everything went smoothly. The bad news is that I can now confirm what most everyone has already said about the lights: they're pretty worthless.
It won't help if they are active. They are basically designed to shine roughly into this (6) area and both the range and the angle are off when travelling at higher speeds, because you would wan't the light more around that (5) area.I suppose they could still release a software update that makes them active at higher speeds?
Assuming the correct hardware (the headlights) are in place, it is both a setting in the menu, but you also have to push the stalk away from the driver to activate it (as opposed to pulling it towards for quick high beam flash). It was not obvious to me at first, either.To my knowledge, it is actually a setting in the menu. So you better check that one
I've drove one with the lights and although it's nothing special it is without a doubt noticable in every corner.
It was dark out as I was driving home, plus I ran some more errands later in the night. I was specifically looking for the lights in corners and curves, but I didn't see anything. Not even something to make me say "wait, that's it?" Nothing. According to the manual, they're always active, so it's not like I'm missing a setting. Maybe my car thinks it doesn't have the lights, so the software isn't activating them? Who knows.
Also, I didn't get a firmware update with the service visit, despite being on .46.8 and .48 being out. Probably doesn't actually matter any, but interesting regardless.
