montgom626
When I do a range charge overnight, it finishes at around 2am @ 273 miles, and by the time I am ready to leave it is down to 260 or so.
You are up at 2 am checking on the SOC? Man after my own heart :biggrin:
And checking for updates, of course! ;-)
Given the big drop, I assume this is prior to V4.0 and display Sleep Mode? It also invites the question I posted on another thread about Standard mode charge: At what point (timer? SOC?) will the Model S re-initiate charging when the car remains plugged in after completing a Range mode charge?
I am running 4.1 and I do not use sleep mode...at least not intentionally. I have the setting set to "off", but some are saying that it activates anyway after 2 hours.
It took ~90 minutes on a 14-50 (232V, 40 A) to charge from 239 (where std charge left off) to 270 (where range charge ended).What are folks experiencing in time, when going from a standard charge of 238 to a range charge?
Ron,
It may be counter-intuitive, but the OFF setting turns on "Sleep" Mode. What it means is it is powering off the displays when the car is turned off. The ON setting means that the displays stay powered on.
Larry
Yes. I have sleep mode off, meaning the displays are powered on...which jives with the instant-on behavior I am seeing. But I am seeing instant-on even after leaving it overnight, where it seems like it's supposed to remove power to the screens after 2 hours even with the settings I have?
In early software revs the S never re-initiated charging if you left it plugged in. By 'never' I mean that I never saw it, though to be fair, I never let it sit more than a week or so without driving. More recently, the car wakes up every 24 hours or so to top off the charge. It's not very consistent, though (I've seen anything from 22 to 24 hours) so I wonder if it's on an SOC trigger rather than a timer. But that's not likely since the timing of reinitiation hasn't changed since Sleep mode was enabled.
Thanks, that is the most definitive info yet. Can you tell from your logs how many kwh it uses to top off and from that back into what the SOC was at the time it re-initiated charging?
I can now confirm that re-initiation does happen with 4.1. I don't have very granular numbers, but overnight i saw 234 rated and now in the morning it is at 239. I have not unplugged the car since Tuesday at 6pm. i will try to get some more data points, as it will remain plugged in until Sunday afternoon.
Wow! 10 miles per day. 100 miles for 10 days! I wonder how much less with sleep mode on.In another thread (cold weather battery drain or some such), I've noted my car has been initiating charge at 230 miles rated range every night (takes about 26 hours to lose 10 miles). This is in a garage at about 55F ambient, MC at 240/40, software 4.1, and sleep mode off.
What would be really neat is to have the ability for a smart phone to "wake" the car up remotely - so as you head to your car say from a high rise, you go ahead and wake it up so theres no waiting when you get to the car. Or even have it warm or cool the compartment and battery so it's totally ready to go...
Cinergi, please bite your tongue and just let us know when Apple will release the App!? Heard from Tesla that it is in their hands...
At least at the Gilroy supercharger there are a pair of 32A Chargepoint chargers also so if someone wants to "top off" they could move over to those and leave the superchargers for folks needing fast charges. I fear people camping out on superchargers will become a problem.Did a "Range" charge at the Barstow Supercharger site earlier today. Had about 40 miles showing when I started it. 2 hours later it still hadn't shut itself off. Had backed off to 4 - 5 amps! Seems kind of silly sitting there with a 400 amp Supercharger, getting less than a wall plug. The first hour got it 98%...it was the last 2% that was the issue. Would think they should provide 110v/15w plugs for those who want /need a full range charge, to shift to so as to not tie up the big one.
Don't fear it, expect it.I fear people camping out on superchargers will become a problem.
