Ok, maybe the maximum permitted draw has been increased by firmware updates. I'm on 1.15.14 and my dash display would should this for instance when at a SC:
225/225 amps, 364/400 v
or
160/225 amps, 364/400 v
That is what led me to believe that 225 was the maximum amperage. Furthermore, this was consistent at Gilroy, Harris, and Tejon SC.
Yes, that is definitely different than what I'm seeing on 1.15.14. They upped the maximum allowable draw to 255.
I don't remember seeing kW/kWh being displayed when I was supercharging on 4.1 two weeks ago. Did that change in 4.2 or is there a way to select that display rather than miles added?
or
@weccman - Theory: (Like my vehicle yesterday...) it didn't reset your "+" mileage from your previous charge.
I'm not sure I understand your theory, but if it is that the + mileage started at 50, that still does not explain why the plus mileage is 246 and the mileage in the battery is 211. Also, while I didn't take a picture of it early in this charge cycle, I'm pretty sure it started at 0, so I am still wondering where the additional 80 kWh [246-(211-50) = 80] went. Were they disbursed as heat losses? Or is there something wrong with the calibration of the + mileage readout?
Some have experienced where the "+" miles start at the total number of miles you added during your *last* charging session. For example, if I came home at 216 miles range, and the car charged up to 240 miles, I added 24 miles. When I start my next charging session, it starts from "+24" and goes from there, and will look like I added 24 more miles than I actually did when that charge completes.
It's highly likely that the *last* time you charged before this, you had added 85 miles of range by charging, based on this theory, and that's what the "+" started with.
Cinergi. Nice graph!
Yeah! Great idea how to present it all on the same scale.Agreed! Excellent data and presentation.
Excuse me for asking this without reading the whole thread first... I did read every post by cinergi since the graph was posted.
I'm surprised that the relationship SOC vs kWh is not strictly linear. How exactly did you obtain the kWh value used for the x-coordinate?
EDIT: And how is it possible that with 33 kWh the SOC increases by 50%?
