FastLaneJB
Yeah I did see a few of those videos. Lots of them raved about it so good press indeed. Of course took them a good while to come out with some carbon ceremic brakes to enable 200mph.
Top Gear were invited and they posted the video below
I actually changed to the wheel and went to 7 seats on my X order about 6 weeks ago). Order agreement has updated with no change to the base price (£89990).I’m tempted to switch to the 21” Arachnids and go for the carbon ceramic brake kit if I’m given the option to change my spec closer to delivery.
I’ll only do so if it doesn’t impact the original base price for the car (pre-£10k increase), though worst case I’ll order after they deliver the car.
I also want to swap to a normal wheel and I hope they offer that to everyone with no penalty (those who locked in the lower base price).
Yes of course, it's a very fast GT car in my opinion. Too big and heavy to be a track weapon though doesn't mean it might not be fun to go down the straights with it.The top gear one was reasonably complementary but they did make the point its still not really a drivers car. I'd suggest you have a read of the MS subsection or go and read on twitter because the cars aren't without issues either, although in fairness I imagine a 200mph Ferrari is also a little temperamental.
Unfortunately full ceramics are eyewateringly expensive.It's a bit of a pisstake that you have to spend 20k on a 120k car for some decent brakes.
But as with the rest of the Plaid they will fall into my "why not?" category.
They upgraded the pads they used didn’t they recently. Not sure if I’ve read or seen anything talk about those but I feel it’s a safe assumption they should be better than before. For road driving, hopefully good enough but for track obviously not.Interestingly, actual objective braking results for the MS Plaid are OK - even better than a Taycan Turbo S according to Car and Driver. The issue is brake fade from repeated use from high speeds (e.g. on track 140 to 40 mph). Since the Plaid will be for commuting, I don't expect to really need CCBs. But as with the rest of the Plaid they will fall into my "why not?" category.
Maybe not as flush as some of you, I’d struggle to justify the carbons when I wouldn’t track it
The CCB material and pads are really about resistance to brake fade after repeated stops in principle. However, it seems the Plaid brake upgrade also has larger rotors (up to 410mm fronts) and 6 piston calipers front, 4 rear - as opposed to 4/2 for the standard brakes. So indeed should also have better stopping power.Is it just brake-fade from repeat heavy braking or a significant difference in stopping? And will it only make a difference when I am trying hard (I don't drive like that any more)
If every time I stop I go "Wow" ... same as every time I'm first-at-the-lights then I'm in.
The standard brakes should really be fine (per the spider graph I posted) - its more about repeated stops.They upgraded the pads they used didn’t they recently. Not sure if I’ve read or seen anything talk about those but I feel it’s a safe assumption they should be better than before. For road driving, hopefully good enough but for track obviously not.
Maybe not as flush as some of you, I’d struggle to justify the carbons when I wouldn’t track it. Not going to be that many places in the UK you can stretch this cars legs enough to also get brake fade I suspect on public roads. I imagine it’ll handle 60 - 70mph braking just fine
Just to assist your understanding. That final bit about finance is probably where you are misunderstanding what really happens.I'm not sure that once I'm in for £120K that another 20K would be hard to find ... I'd make the assumption that I'd get 50% back on sale, so its the finance cost of (another!) £10K over X years ...
A bit? Porsche would never launch a car with such crapola brakes, even if the owner never drove to the car park of a track.It's a bit of a pisstake that you have to spend 20k on a 120k car for some decent brakes.
Do people really have to seek finance when they can throw that much at a car? I would have thought you just write a larger cheque … or whatever young people do these days. Those wealthy enough seldom have to trouble themselves over £10k here or there
given the speeds you might reach in such a short amount of time, you need to know you've got commensurate stopping power under your right foot.
I also agree on a fundamental level that you should not have to spend another £20k on a £120k+ car that does 0-60 in <2 seconds for brakes that are actually up to scratch
You don't, but someone else might. For example your German alter ego who goes up and down the autobahn everydayBut its "might reach" surely? I have no intention of driving mine at 160 MPH "'coz it can" - and certainly not to then repeatedly stand on the brakes.
